Go to Post Don't Canadians spell it that way? Someone should cheque on that.... - Travis Hoffman [more]
Unread 06-02-2008, 18:36
Re: Problem with our Victor?
You know, I think Don Rotolo is right, I can see some electrons leaking out in one of the pictures. What you need to do is go find all the electrons that dripped out and return them to the module. You might have to go to a local electron supply depot to get enough to completely fill the device. Then you will need some Acme Electronik Leak Sealer with testing dye. Use according to the labeled directions and certainly wait the required length of time for it to cure. I believe it may need a vacuum of at least 40 inches of mercury for the curing process. Then you will need a variable voltage source, and starting at a very low voltage (1x10^-10 volts) and slowly advance the power supply while watching for the tell tale electron leak to occur. Most repair stations will perform this in a photographic room with the lights off. If all the electrons leave at once then I am afraid this device may be impossible to repair. Give it a good funeral and bury in the back yard along side Fluffy, the faithful goldfish from your youth.
Unread 06-02-2008, 18:38
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Your Victors came with the wrong topology... They are supposed to work in an H-bridge, yours had a short "I-"bridge. Call IFI and claim DOA!
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 07-02-2008, 01:28
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
You have too much whitespace between the sections of the victor. Remove it and apply duct tape (not masking tape) to seal it.
Also, the Coriolis effect may be causing the electrons to orbit the central capacitor in the wrong direction. Did you obtain this particular speed controller from the southern hemisphere?
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
Unread 07-02-2008, 01:57
dtengineering's Avatar
AKA: Jason Brett
There is no problem at all with this Victor. It is simply undergoing mitosis. Wait a few days and you should have two nice new Victors ready to go. Isn't that how IFI does it?
If you simply can't wait that long, I suggest you use the bandsaw to induce mitosis in your RC, so that it is at a similar state of division and better able to communicate with the speed controller.
Jason
Unread 07-02-2008, 08:14
GaryVoshol's Avatar
Cogito ergo arbitro
Would zipties help?
(since 2004)
Unread 07-02-2008, 09:33
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
I don't see how this could be a hardware problem, must be a software problem.
Unread 07-02-2008, 10:27
It looks like you have configured your Victors for a Beowulf Cluster approach. Be sure that you load an OS that supports it.
Unread 07-02-2008, 18:35
nedpirates nedpirates is offline
First Mate
AKA: DudeZ
FRC #1584 (Pirates)
nedpirates is a jewel in the roughnedpirates is a jewel in the roughnedpirates is a jewel in the rough
Hey all,
Thanks a ton for the advice, especially the mitosis bit. That led us to believe that you might be on to something there so we called in a specialist (an electronics biologist who knows about Victor reproduction). Turns out that it's actually undergoing meiosis so we're going to try to splice them by soldering them together. We calculated the % yield of majic smoke (we checked the spelling on that and it's actually "majic") and we're coming up about 12 cc short of the needed amounts. So we still need more of that (IFI is back ordered until 2009 and majicsmoke.com doesn't carry the old stuff anymore. Does overstock.com have it?).
We also attached some magnets to get the electrons to orbit the right way and installed Redhat because it supports the Beowulf Cluster configuration emulator but every time we try to tape it back together it flanks the adhesive and massacres it before it even touches the Victor (can you set the aggressive setting to "passive" or anything?), oh yeah, it also killed all our trunk monkeys and they smell really bad.
Hope you guys have some ideas because we're helpless without this speed controller.
Thanks,
The Ned Pirates
Unread 08-02-2008, 07:32
I have tons of old Majic Smoke here, some with date codes that go back into the sixties. However, I have no method of acuumulating the smoke, nor a method of measuring out 12 cc. I would assume you would want more than the minimum in case some leaks out during transfer. However, I cannot guarantee which region the smoke was injected from. Do you have a particular vintage of smoke you are looking for? White or Black or a blend perhaps? Tight curling smoke or straight line smoke? Please advise, awaiting your (cough, cough, there goes another one!) reply.
Unread 08-02-2008, 16:02
kjhobin kjhobin is offline
AKA: Keith Hobin
FRC #3314 (Mechanical Mustangs)
kjhobin is a jewel in the roughkjhobin is a jewel in the roughkjhobin is a jewel in the rough
Send a message via AIM to kjhobin
Lightbulb Re: Problem with our Victor?
It can't be a software problem, because C ignores white space!
Also, the majic smoke must be blue! Its always blue majic smoke!
Montclair Robotics FIRST Team 555 Alumni
FIRST Volenteer
Unread 08-02-2008, 22:38
Well then, I can't help you there. All my smoke comes from the days before "living color".
Unread 11-02-2008, 23:30
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
nice job
R.C.
MadTown Robotics Team 1323
Unread 18-02-2008, 00:33
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is online now
Coach
FRC #1086 (Blue Cheese)
This thread gets an "A+" From a high school physics teacher! It's what i've needed after 6 long weeks of building!
Now about the "problem"... All our Victors looked that way when we pulled them out of the box 6 weeks ago. They didn't work for us either. After much thought and observation we deduced that the spin on our electrons were backwards. In order to compensate for this, simple replace the terminal posts with left handed screws and it will work perfectly!
PS: that whole mitosis stuff is a bunch of garbage anyway. Those darned Biologist think they are "real" scientist when they only practice applied chemistry and everyone knows that chemistry is really applied Physics. trust me on the this: change the screws!
Unread 19-02-2008, 19:11
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
You should try applying anti-matter to the Victor's surface. That should give you enough pure energy to run your CIMS for the entire competition. Just make sure you don't wire all your CIMS to this one Victor, that's against the rules!
Victor 884 problem Gal Longin Control System 11 26-01-2005 00:47
Victor 884 problem Gal Longin Electrical 11 26-01-2005 00:47
Victor problem Andy Baker Electrical 15 24-06-2003 09:49
Victor Size Problem Jeff Waegelin Inventor 3 24-02-2003 15:35
Victor controller problem llambele Technical Discussion 3 14-11-2001 23:00
