Go to Post If people are getting offended at seeing other teams list their accomplishments, maybe they should spend less time whining and more time doing things to make their own team win. - artdutra04 [more]
Unread 08-02-2008, 08:08
ERAUeagle68 ERAUeagle68 is offline
FRC #0540 (Screaming Eagles)
Team Role: Electrical
ERAUeagle68 is an unknown quantity at this point
pic: TEAN 540 E-BOARD 1
Unread 08-02-2008, 08:10
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Re: pic: TEAN 540 E-BOARD 1
We got caught on this also, check out:
<R50> The 12V battery, the main 120-amp circuit breaker, the power distribution block, and circuit
breaker distribution panels shall be connected as shown in the 2008 Power Distribution
In particular:
• All circuit breaker distribution panels must be connected directly to the power
distribution block. No intermediate connections are permitted.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 08-02-2008, 08:40
I think what I have done is legal, because I have done it for the past 3 years and never had anything said by the inspectors. Also that same rule was in the rules last year and i did not have to change it at competition. But i will take the stuff I need to fix it at competition. Thanks for the info.
This is from the Rule Book last year
<R57> The 12V battery, the main 120-amp circuit breaker, the power distribution block, and circuit
breaker distribution panels must be connected as shown in the 2007 Power Distribution
Diagram. In particular:
 The battery must be connected to the ROBOT power system through the use of the
Anderson Power Products (APP) connector.
 The APP connector must be attached to the battery with either the copper lugs provided in
the FCI Burndy Bag or appropriate crimp-on lug connectors.
 The battery terminals and the connecting lugs must be insulated with shrink tubing and/or
electrical tape.
 The main 120-amp circuit breaker must be directly connected to the hot (+) leg of the
ROBOT-side APP connector. Only one 120 amp main circuit breaker is allowed. This
breaker must not be bypassed.
 The power distribution block must be directly connected to the APP connector and main
120-amp circuit breaker. No other loads may be connected to the main 120-amp circuit
breaker.
 All circuit breaker distribution panels must be connected directly to the power distribution
 Additional lengths of #6 red and #6 black wire may be used to reach the panels as needed
to make the above connections.
 Circuit breakers must be accessible for inspection at each FIRST Robotics Competition
event.
2005 NASA/VCU Quarter-finalist
2006 NASA/VCU Regional-Semi-finalist
2006 FIRST Robot Rumble-Quarter-finalist, Most Promosing Rookie Drive team
2006 Championship-Curie
2007 NASA/VCU- Regional Winner
2007 Championship-Galileo
2007 FIRST Robot Rumble-Semi-finalist
Unread 08-02-2008, 09:06
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
<snip>
Then you, my friend, got lucky. I urge you to fix the problem before ship date, there will no doubt be many other things to do come Practice Day, and you want to a) pass inspection as fast as possible, and b) make inspection as painless and easy as possible for you and the inspectors. They /want/ to pass you but they can't ignore the rules.
Unread 08-02-2008, 09:37
Mentor,QCR Planning
Precisely. 2 years ago at Pittsburgh Regional the inspection process consisted entirely of weight and dimensioning and that was it . No pit inspection of electrical, pneumatics, or anything. They didn't have the personel to do it. At other regionals the inspection is more complete and that mistake would certainly be found.
Unread 08-02-2008, 10:04
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
It's not legal my West End Friend. I would change that ASAP.
pic: Team 540 Frame ERAUeagle68 Extra Discussion 2 02-02-2008 00:00
pic: Team 540 Air Cannon Rob2713g Extra Discussion 5 22-12-2007 03:53
pic: Team 540 Button Cloak Rob2713g Extra Discussion 7 23-03-2007 07:47
pic: FRC 2108, 540 kjohnson Extra Discussion 26 13-03-2007 17:43
pic: Presenting Teams 384, 540 and 1086 Crebb Robot Showcase 28 12-03-2007 08:04
