ADXRS150 Gyro Yaw Sensor sensitivity?
Hello.
I am trying to use ADXRS150 sensor but I am not sure the sensitivity of the sensor. How many volts does it go up(or down) with one degree rotated? Is this on the spec sheet? (I can't find this...) Thank you |
Re: ADXRS150 Gyro Yaw Sensor sensitivity?
Spec sheet says: 12.5 mV/deg/sec
Remember it is a yaw RATE gyro which means voltage changes from 2.5 V nominal proportional to how fast the turn is as opposed to how far it turns. |
Hope this helps. - Voltage correction added after comment by Alan Anderson - 02-08-08 MBCLast edited by marccenter : 08-02-2008 at 09:21. Reason: Critique by Alan Anderson |
The sensitivity is 12.5 millivolts per degree/second. The maximum rate is 150 degrees/second. That means the maximum deviation from neutral is 1875 millivolts, yielding an output that ranges from .625 volts to 4.375 volts. It's nit-picking, I know, but I wouldn't call that "nearly 0.0" or "nearly 5.0" volts.
If I am reading the rules correctly, you cannot use the ADXRS150 from the 2007 KOP. Is this correct?
I will update my original post with your values of 0.625 volts and 4.375 volts.Last edited by marccenter : 08-02-2008 at 09:22. |
| Yaw Rate Gyro Problems | RetroKamikaze | Programming | 3 | 27-01-2006 20:55 |
| ADXRS150 gyro yaw rate sensor | Brian M. | Electrical | 13 | 17-10-2004 02:28 |
| ADXRS150/300 Sensor | m0rph3us | Electrical | 2 | 06-02-2004 22:37 |
| Yaw rate sensor (gyro for the layperson) | Kris Verdeyen | Rules/Strategy | 4 | 14-01-2002 00:41 |
