Go to Post Each team is different, your mileage may vary. What works for your team does NOT necessarily mean it will work for others. - Andrew Schreiber [more]
Unread 08-02-2008, 08:43
Browzilla Browzilla is offline
Fearless Leader
AKA: David Vriezen
FRC #2530 (Team Inconceivable)
Team Role: Electrical
Browzilla is on a distinguished road
Send a message via AIM to Browzilla Send a message via MSN to Browzilla
Ball Knocker Advice
Here's our basic setup so far. We've got about a 4'2" 1.5" PVC Tube set to be mounted to the kitbot frame at about 5" above the ground. We plan to knock the ball off with a telescoping PVC pole.
We /had/ planned to run it up using the black ribbing in the KoP and the gears provided, which if we measured correctly should give us about a 3:1 gear ration and about 26"/sec.
While assembling yesterday, we came across a slight problem: our setup yesterday had used 2" pipe with 1.5" inside, with a track milled out because the ribbing wouldn't quite fit into the 2" pipe.
After this, we're strongly considering a winch and pulley. It's simpler overall, I think, and we could still gear up the spool; in order to get the same 26"/sec I think we need about a 2" spindle.
I'm asking here whether any of you teams with more experience can advise us in either direction. The milled pipe wouldn't be to hard to fix, but the winch is looking pretty good right now too.
Unread 08-02-2008, 09:08
BlackBird11891's Avatar
BlackBird11891 BlackBird11891 is offline
We Rise Above Our Challenges
AKA: Chad Krivanec
FRC #1927 (Team Tempest)
BlackBird11891 is on a distinguished road
Re: Ball Knocker Advice
cap the top of the pvc pipe and use a compressor to shot about 30 psi. into the pipe to launch the second pipe up to knock off the ball
Unread 08-02-2008, 09:09
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
With a winch, you need to be wary of tangling. If set up and operated correctly (have some sort of indicator when fully retracted and extended so the RC knows when to stop based on sensor feedback, perhaps a string pot or an optical sensor) it is normally not a problem.
Unread 08-02-2008, 09:15
Fearless Leader
AKA: David Vriezen
Will that be enough power to get the ball up? Due to the robot's height, we need to extend a pipe roughly 4'2" up at least 2 feet just to hit the ball, and then it's unpredictable as to where it goes. A pro of the winch/gear thing is that you get controlled speed, so you can go with either reckless flying balls or just tip the ball off more slowly.
Unread 08-02-2008, 09:20
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
You might want to consider a hinged mechanism also....and if it has pneumatic actuation it will be kind of "springy" and might not need to be retracted to go under the overpass. also think about using a flexible part to knock the ball off.
We don't have any solid part of our robot extending past about 75" height, ever. We discovered that it really is not very difficult to knock the ball off. And catching it is the fun part....
Unread 08-02-2008, 09:21
AKA: Chad Krivanec
we tried it by regulating the pressure so that it went up fast but as it reached the top it started to slow down just enough to pop it off
Unread 08-02-2008, 09:29
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
We are working on our "ball popper" as well. We have a 24" throw piston to play with for actuation. We've run into two problems: 1. Where to place the device so that it won't tip us over when it strikes the overpass and where it won't interfere with our other device. 2. The Geometry of the ball makes punching it off the overpass a very interesting challenge. I guess this is the problem with putting something in as an after thought.
Unread 08-02-2008, 09:37
MrForbes's Avatar
AKA: Jim
here's an example of knocking the ball off and catching it...
http://www.chiefdelphi.com/forums/sh...ad.php?t=63236
and I think there is video of it somewhere also, but I can't find that just now.
(they've reinforced the "twisty" parts since this picture was taken!)
Unread 08-02-2008, 09:54
BenB's Avatar
BenB BenB is offline
AKA: Ben Bennett
FRC #1114 (Simbotics)
BenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond repute
Are you talking about hitting it off with some device, or actuating something and then running into the ball? Has anyone calculated approximate forces required to do either of these actions?
2010-present - Team 1114 - Simbotics
2007-2009 -Team 2166 - Bluebotics
Unread 08-02-2008, 10:22
MrForbes's Avatar
AKA: Jim
You could just run into the ball, I think 842 either runs into it or flips up the arm to hit it (ask them, they'll probably tell you). Try it, see what happens.
Unread 08-02-2008, 10:25
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
That would constitute a Pneumatic piston and you are not allowed to build your own.
Steve
Unread 08-02-2008, 12:38
Fearless Leader
AKA: David Vriezen
As of last night our plan was to have a 2" diameter pipe with a 1.5" pipe inside. Mount a pulley of some sort at the top to prevent cable wear and friction, and then increase the inches/sec by either attaching the winch spool to either a gear geared up to a better ratio or by using multiple pulleys.
Unread 08-02-2008, 12:42
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Steve is right. Chad, what you describe is not a legal use of pneumatics, and will not pass inspection. It's kind of unfortunate, but it's good that you still have time to come up with a new solution.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 08-02-2008, 18:13
ewrado's Avatar
ewrado ewrado is offline
FRC #0842
ewrado will become famous soon enough
to nock the ball off make an H out of pvc that flips up before you get to the overpass then just drive under the ball and the ball falls off
Unread 08-02-2008, 20:10
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
we can knock the ball down by extending the top of our elevator up to about 6' 5" and just run under the ball and it just pops right out
-Dustin Benedict
recruiting advice? insub2 Finding A Team 12 22-09-2008 12:54
WHere do you get Ball Casters/ BAll Transfers for FRC?!?!?!? leehyungjin4u General Forum 3 15-01-2008 23:27
Advice Garth1388 Rules/Strategy 13 11-03-2006 02:40
2X Ball Into the Ball Release MikeDubreuil Rules/Strategy 23 28-03-2004 19:31
We can extend beyond the playing field with our ball-knocker-offer??? Natchez Rules/Strategy 35 19-03-2004 09:35
