Go to Post Their robot moves so fast that it changes colour due to the Dopler Effect. By rapidly alternating between driving away from the viewer (Redshift) and driving toward the viewer (Blueshift), they can make the viewer see it in their traditional purple colour. - philso [more]
Unread 08-02-2008, 10:09
A.Tup's Avatar
A.Tup A.Tup is offline
AKA: Adam
FRC #2620 (Village Idiots)
Team Role: Driver
A.Tup is an unknown quantity at this point
Send a message via AIM to A.Tup
Re: Joystick help (Rookie)
ok thank you all for all the help
Unread 08-02-2008, 10:33
Adam,
Something no one mentioned is to ask the question "Are your speed controllers calibrated?" Quite often, the Victors do not match the charachteristics of your joysticks. Move your joysticks forward and reverse and see at which point the Victor LED is fully red and fully green. If this occurs at less than full travel on the joystick, you need to calibrate the Victor. For teams who do not perform this calibration in the software, the only way to calibrate is following the method in the 884 users manual found on the IFI website. This procedure matches the full travel of your joystick to the full output of the Victor. The joysticks and the Victors are not matched before they are put in the KOP.
Unread 08-02-2008, 11:51
A.Tup's Avatar
AKA: Adam
Team Role: Driver
ok thank you i will check that next time in with the robot thanks again
Unread 10-02-2008, 13:32
corcarter's Avatar
corcarter corcarter is offline
AKA: Corey
FRC #2620 (TBA)
Team Role: Electrical
corcarter will become famous soon enough
Send a message via AIM to corcarter
i think our driver just needs to learn how to drive!!!!!
good year fellas and ladies, good year
Help with joystick lightning_blast Programming 2 12-02-2006 22:25
Rookie help doyler Technical Discussion 55 11-01-2005 08:59
VB6: Joystick help! Astronouth7303 Programming 0 15-06-2004 17:05
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
Joystick Help archiver 2001 0 24-06-2002 01:02
