Go to Post Enlighten a man who sometimes has difficulty understanding why others stray outside the box, when the box appears to be an optimized and elegant solution. - JVN [more]
Unread 06-02-2008, 12:50
jfrank's Avatar
jfrank jfrank is offline
FRC #2668
jfrank is an unknown quantity at this point
Question autonomous help
does anyone have code to make the autonomous code to turn on and off with a switch hooked up to the tether port of the board???
Unread 06-02-2008, 13:06
eaglesfan10's Avatar
eaglesfan10 eaglesfan10 is offline
FRC #1647 (Iron Devils)
eaglesfan10 is an unknown quantity at this point
Re: autonomous help
You don't need to program anything- determining if you're in autonomous or not, is determined by the oi's competition port. You'll have to make an autonomous switch. A diagram of the competition port can be found here:
http://www.ifirobotics.com/docs/comp...guide-reva.pdf
Or you could just buy one from andymark:
http://www.andymark.biz/am-0016.html
Unread 06-02-2008, 13:49
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: autonomous help
To compliment what eaglesfan said - if you make one of those switches, then you'll be certain that your autonomous mode will run properly during the competition, since that is how they control what state every robot is in when it's competing.
Unread 07-02-2008, 12:22
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
Question Re: autonomous help
We have one of the dongle switches, and pins 5 and 8 are defiantly connected, yet we still can not initiate autonomous mode. I don't have the code in front of me, but our programmer (he is new) tells me that the auton. declaration section is right. Can any one help?
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 07-02-2008, 12:57
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Re: autonomous help
You shouldn't have to touch the code to get the switch to work. It should work by default. Make sure your switch connects 5 to ground in one position, 8 to ground in another, and doesn't connect anything in regular mode. For example, on a 3 state switch, you'd have 5 on the top, 8 on the bottom, and ground on the middle. Use a meter to make sure you switch is working too.
Oh and double check the pinout. I fried the OI last year setting up the atonomous switch.
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 07-02-2008, 20:45
hipsterjr's Avatar
AKA: CJ
Re: autonomous help
It's the same switch we have used for years, so that can't be the problem. Something on the OI or code must be set wrong, but I'm not sure what. Driver mode and disable work fine though. The RC mode reads blinking yellow (meaning auton.) but acts like it is in disabled mode even though there is "valid" code under the auton section.
Unread 07-02-2008, 21:39
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
Re: autonomous help
There's a thread about it here and probably others exist.
We're always willing to help out and answer questions, but it really helps if you search before you post.
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
Unread 07-02-2008, 23:46
Re: autonomous help
What does there is "valid" code under the auton section mean? Show us this code so we have something on which to base our advice.
Unread 08-02-2008, 10:25
Re: autonomous help
That blinking yellow indicator on the OI therefore means "invalid auton code."
AUTONOMOUS HELP RDD Programming 2 12-02-2007 15:24
Autonomous Mode HELP! jesusescobar Programming 4 12-02-2007 12:02
HELP ON Autonomous !!!! jesusescobar Programming 1 10-02-2007 20:45
Autonomous Help sudeepr71 Programming 14 10-03-2004 22:14
Autonomous Help mightywombat Programming 11 07-01-2004 10:45
