Go to Post It's kind of magical how I went from legos to replacing most of the iron in my blood with aluminum, and all thanks to my elementary school science teacher. - Astrokid248 [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 21:57
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: Blowing Relay Fuses
Posted by Tony K.
Student on team #292, PantherTech, from Western High School and DaimlerChrysler.
Posted on 2/22/2000 10:31 AM MST
In Reply to: Blowing Relay Fuses posted by Nate Smith on 2/22/2000 8:56 AM MST:
Open up the light housing and see if the positive terminal is shorting to the housing. Also, make sure it's mounted on Lexan or something else to insulate it from the robot body (ground fault, maybe?). Have you tried another spike?
Tony
[IMG] code is Off
20 amp fuses for Spikes Andrew Schuetze Electrical 8 01-04-2003 22:18
Wiring the relay for the pnumatics Placebo OCCRA 3 05-11-2002 23:04
Spike Relay Input nwagers Electrical 3 16-07-2002 22:23
Triping Timed Fuses Joe Canavan Electrical 2 21-02-2002 09:34
Relay Outputs OddOne Technical Discussion 3 01-02-2002 19:52
