Go to Post Maybe Dave's just bananas for FVC? - Billfred [more]
Unread 07-02-2008, 11:33
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
burned IR sensor..
Hello guys ...
we wired the sensor to frc controller ( pwm output ) as a power supply ..
which supplies 7.2v..... i worked for few days .. then it stoped functioning .. i think we fried it ..
my question is : do the pwm outputs supply a larger value of current which the sensor con not accept ?
or there is another error occured ?????
i read this :
http://www.chiefdelphi.com/forums/sh...light=infrared
Unread 07-02-2008, 11:51
Aaron_H Aaron_H is offline
FRC #1033
Aaron_H is on a distinguished road
Re: burned IR sensor..
Read the thread "Dead IR receiver Module". See if those symptoms are the same.
Unread 07-02-2008, 11:57
Originally Posted by yara92 View Post
Hello guys ...
Did you recharge the backup battery? That's the source of the 7.2 volts on the PWM pins.
Unread 08-02-2008, 11:56
yara92's Avatar
AKA: Mohamed
we are tring to fix it by some one who is good with electronics
thank you for your trying to help us
Unread 08-02-2008, 12:19
Mohamed,
The IR sensor is intended to be connected to the +12 volt power through a 20 amp circuit breaker. The power from a PWM output is right at the minimum operating voltage for the sensor board. (7-12 volts as stated in the documentation.)
IR Sensor mechman9113 Programming 9 29-01-2008 16:18
IR Sensor fabalafae Programming 1 19-01-2008 16:53
Sensor Molten Programming 3 17-02-2007 17:43
Anybody else burned out? PMGRACER General Forum 52 18-01-2004 19:14
Sensor or no Sensor For Autonomous mode Kyle1010 Programming 14 22-01-2003 13:10
