Go to Post Last I looked, FIRST wasn't an acronym for inspiration and recognition of robots. It was and is an acronym for inspiration and recognition of science and technology. - JaneYoung [more]
Unread 08-02-2008, 00:25
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
Serial_Write_Char() - Question
Hi,
When using the "Serial_Write_Char()" function I know the correct syntax is "int port,int ch_out."
However when I use "Serial_Write_Char(TTL_PORT,52);" the "Program State" LED stays orange. What am I doing wrong?
Thanks,
Nathan
Save money with PriceWombat, a shopping comparison and price tracking tool (that I made!).
Check out my hobby electronics business!
My former robotics team: Huntington County 4-H Robotics
Unread 08-02-2008, 12:58
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Re: Serial_Write_Char() - Question
Running IFI default code? Called Serial_Driver_Initialize() before hand? Did anyone modify the IFI default low interrupt handler and remove CheckUartInts() call?
A random guess is the interrupt flag is being set but never cleared.
Unread 08-02-2008, 14:11
Nathan's Avatar
This is the end part of "User_Initialization" in user_routines.c
  relay7_fwd = 1;
  relay7_rev = 0;
  Initialize_Falcon();
  Putdata(&txdata);             /* DO NOT CHANGE! */
  Serial_Driver_Initialize();
  printf("IFI 2006 User Processor Initialized ...\r");  /* Optional - Print initialization message. */
  User_Proc_Is_Ready();         /* DO NOT CHANGE! - last line of User_Initialization */
The "Initialize_Falcon()" is where I try to write to the TTL port. As you can see it IS above "Serial_Driver_Initialize()," but I can't move it down because the it would be below Putdata?
Thanks,
Nathan
Unread 08-02-2008, 14:54
AKA: Bud
I'm not sure I see the problem of moving it down. But if you can't, you can't (not sure why as IFI initialization has already done two Putdata() calls to init both low level buffers). Try the following..
  relay7_fwd = 1;
  relay7_rev = 0;
  statusflag.TX_UPDATED = 0;    /*reset these to update latest data later*/
  Putdata(&txdata);                  /*put data out again */
Unread 08-02-2008, 15:04
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
I don't see why you shouldn't be able to move the Initialize_Falcon down, but you can definitely move the serial initialize up. In any case, you have to call the initializer before you can use the serial ports.
Unread 08-02-2008, 16:13
Nathan's Avatar
Ok, so I actually ended up moving my initialization function to process_Data_From_Master_uP() and just making sure it only gets called once.
It works now :-)
Thanks,
nathan
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
