Go to Post Point is, there is no definite answer. This is FIRST, Whatever works well with your team is the best. - NelsonMichael [more]
Unread 08-02-2008, 15:35
Re: Large Backup Battery
Originally Posted by gurellia53 View Post
Our team is using AndyMark Super Shifters this year with servo shifting. I've read here on CD, and found out through testing that the servos drain the backup battery very fast. My question is are we allowed to take 12 NICAD cells and wire it so that we get 7.2 Volts, but twice the milliamp hours? (6 parallel pairs in series)
I know its not legal to use 2 batteries, but I believe this would be considered 1 battery.
Thanks,
Andrew
Going out on a limb...NO. Never parallel batteries.
You can buy larger capacity battery packs from places like Digikey. You can also use the IFI onboard charger (although I don't personally recommend that). I believe Digikey has packs up to 1100 maHr.
Backup Battery Tottanka Electrical 31 06-01-2008 22:41
Backup battery connector jgannon Electrical 2 16-04-2007 16:03
backup battery carbuff Electrical 1 19-02-2007 08:28
backup battery nirty Electrical 1 08-02-2006 14:40
Backup battery and IR Matthew_H Electrical 6 21-01-2004 22:13
