Go to Post We started FIRST to achieve a common goal and not only will we leave with more knowledge and wisdom, we will leave as friends and thats what really counts if you ask me. :cool: - Hick18 [more]
Unread 08-02-2008, 16:09
farm3rboy101's Avatar
farm3rboy101 farm3rboy101 is offline
Wisconsinite
AKA: Andrew Boldt
FRC #1732 (Hilltoppers)
Team Role: Electrical
farm3rboy101 is on a distinguished road
IR Board? Both wires or just one?
We were wiring our IR board, when we realized that it said 1 OR 2 goes to positive, and 3 OR 4 for negatives. Then, we saw some other teams using the IR board using BOTH 1 AND 2 for positive, and both 3 AND 4 were in the negative.
My team would just like to know which works, and we don't want to fry our board!
Unread 08-02-2008, 16:12
Miner Miner is offline
AKA: Jacob Miner
FRC #2077 (Laser Robotics)
Miner is on a distinguished road
Re: IR Board? Both wires or just one?
Both pins 1 and 2 can be positive, and both 3 and 4 can be negative.
Do what you like... Like what you do!
Jake, the Life Is Good guy
Unread 08-02-2008, 16:24
Wisconsinite
AKA: Andrew Boldt
Just another question, can we have our own battery for our IR Board? as it says in the rules only 7.2 volts and 12 volts are allowed on robot and that's the regular battery and the backup battery. In the video, it says we should use our own battery from 7 to 15 volts. Can we have another battery in addition to the backup, and regular battery, or do we have to wire it to the regular circuitry.
If we have to power it from the regular system, how do we do it?
Unread 08-02-2008, 16:25
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Basically It Does Not Matter... We Hooked Both Up To Make It Neat.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 08-02-2008, 16:30
AKA: Jacob Miner
You are able to wire the IR board directly to the breaker panel, just put it on a 20 amp fuse. The board accepts 7-15 volts so you can use the main battery. I wouldnt use the backup battery because it will drain really fast. We just did this today and it works just fine.
Two 10AWG wires into one distribution block position Richard Wallace Electrical 7 03-02-2008 14:46
Extending IR board connector wires 7-11number1 Electrical 8 14-01-2008 21:49
One wheel skate board EHaskins Technical Discussion 4 03-04-2007 12:10
BattleCry in Just ONE WEEK! WernerNYK Off-Season Events 43 02-07-2006 20:52
Just a thought for the board... archiver 1999 1 23-06-2002 22:03
