Go to Post I have postulated a theory that it is due to a resonance between gravity waves and the color purple. - petek [more]
Unread 08-02-2008, 17:37
Magnechu Magnechu is offline
Student Strategist
AKA: Mike Fouchet
FRC #0870 (RICE)
Team Role: Tactician
Magnechu has a spectacular aura aboutMagnechu has a spectacular aura about
Send a message via AIM to Magnechu
Recycling Air
Can you recycle the released air by the rules? In order for this to work you would need a one way valve, does this exist?
Is their a minimum requirment of air tanks on the robot?
Any answers would help greatly!
Unread 08-02-2008, 17:43
Re: Recycling Air
In regards to your first question, I don't know of anything prohibiting this. You should talk to Q&A first before you do anything, though.
As for the second, the answer is no. You could just have the compressor...but that almost defeats the purpose of pneumatics.
Unread 08-02-2008, 18:32
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Recycling Air
I am curious. What are you trying to accomplish by recycling air?
Unread 08-02-2008, 18:48
Student Strategist
AKA: Mike Fouchet
FRC #0870 (RICE)
Re: Recycling Air
I was thinking about conserving the air so we would have more pressure in the system. I am trying to reduce the amount we use the compresser to have maximum power output for the battery.
Unread 08-02-2008, 19:33
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Re: Recycling Air
What you're describing won't actually help conserve pressure. The cylinders work by using a pressure difference to do work. If there's no difference in pressure between the air going into the cylinders and the air leaving them, they aren't going to move.
Unread 08-02-2008, 20:06
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: Recycling Air
well said. the pistons actuate by creating high pressure on one side of a plate and the lower pressure acts as a vaccum and sucks the rod part of the piston out when working.
-vivek
"we don't build robots, we build people"
Unread 08-02-2008, 23:47
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: Recycling Air
IF you are worried that your battery would die within one match your robot needs to be made more efficient. Someone back a year or two ago figured you would have to run every motor at full speed to really worry about a battery problem.
-Mike
Unread 09-02-2008, 01:27
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Re: Recycling Air
If you want to conserve air, add a secondary regulator and use the lowest air pressure that will do the job. Remember that a 2 inch cylinder will produce over 170 pounds of force with 60psi of pressure. If you do not need this much force, use a smaller cylinder or less pressure. Just be sure to add in a safety factor.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 16-02-2008, 02:34
MailMan's Avatar
MailMan MailMan is offline
AKA: Tom Macgowan
FRC #1570 (Demon Robotics)
MailMan is an unknown quantity at this point
Re: Recycling Air
If you still want to recycle the air, I think the best way to do it would be to use the normal setup (compressor-air tank-regulator-solenoid-cylinder) then on the SMC solenoids they have exhaust ports from the cylinder, then put in a expansion tank such as the KOP air tanks, then you would have to somehow attach a hose fitting to the compressor’s air intake. The reason you would use the expansion tank is because the rate at which the air is coming out of the cylinder is greater than the rate at which the compressor is pumping.
This setup MAY let you pump air faster since the air is coming into the compressor pre-compressed. However, this would also take away power from your cylinders (thus requiring more air the extend the cylinder) making the entire effort pointless, and it would be a lot of work to mount the fittings on the compressor, let alone if it would pass Tech.
reserving air 157#1Driver Pneumatics 5 01-02-2007 16:48
Air Cannon Michael223 Technical Discussion 13 14-06-2006 10:23
Recycling At Regionals (bottles, cans, paper) RobotsVsKittens Regional Competitions 3 27-03-2006 15:42
Are we allowed to use a Bimba air-to-air booster? Alex Minot Pneumatics 1 20-02-2005 22:32
Air Jordan matt111 Rumor Mill 21 03-02-2004 18:59
