Go to Post Wait hold the phone. Do you mean its physically possible to not spend time on robotics during the season?!!! Too much.......for brain......to compute!...goes against.....beliefs........aaaaarrrrrrghhhhhh!!! [syntax error] - BuddyB309 [more]
Unread 02-08-2008, 02:10 PM
Back after 4 years off
FRC #5279
Problems with victor blowing
We tested our drive train today, the victor on one side blew immediately. We then tried blowing out our electronics and replaced the victor. Again as soon as power was sent through the victor it blew (nothing happened when power was on but the bot was disabled). Has anyone had this problem before or do you have ideas on what to check for or what could cause this? We have already checked to see if any power was running through the chassis.
Thanks
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 02-08-2008, 02:15 PM
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: Problems with victor blowing
Are you talking magic smoke time or did the breaker just trip?
Unread 02-08-2008, 02:18 PM
FRC #5279
The Transistors blew, magic smoke and all. The breaker never tripped.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 02-08-2008, 02:19 PM
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
How are the Victors wired to the motors and to power? Which terminals are connected to what? Sometimes people don't notice or understand the markings on the Victors and wire the wrong end to power, which causes things like this to happen.
Unread 02-08-2008, 02:22 PM
FRC #5279
Yes, Power and Ground are going to V+ and V- and the motor is connected to M+ and M-
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 02-08-2008, 02:24 PM
EduardoVemny EduardoVemny is offline
FRC #0743 (Technobots)
EduardoVemny is an unknown quantity at this point
Every so often my Fuse keeps popping even though the board is wired right. In years past I used the 20 amp auto reset breaker where the fuse is supposed to go. Not sure if it is legal this year but once again I've done it in years past
MrForbes's Avatar
AKA: Jim
Is there any way you could get a picture?
Unread 02-08-2008, 02:27 PM
vhcook's Avatar
Reader of Things
AKA: Victoria
I'd also check for a short between your M+ and M- leads. A problem on that side might not affect the robot while the Victor was in neutral.
Unread 02-08-2008, 02:28 PM
FRC #5279
What do you want the picture of? I know they were wired properly, they were identical to the other 3 that worked fine. We have multiple veterans who looked at it and we know that it is wired properly.
James
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 02-08-2008, 02:29 PM
FRC #5279
I believe you are confusing spikes and victors.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 02-08-2008, 03:38 PM
I know this is repetitive and somewhat rude, but what you describe (i.e. multiple failures of the same Victor) tell the tale of the primary wiring backwards. It may be correct at the Victor end and switched at the breaker panel and terminal block but this is classic failure mode for power lead reversal. Sorry, justs trying to help.
Unread 02-08-2008, 04:14 PM
If it were wired properly, it wouldn't be frying Victors repeatedly. Something is almost certainly not identical to the ones that work, and it's obviously something...um...unobvious.
Try powering up the robot with no Victor installed, and measuring the voltage on the wires that you intend to connect to the V+ and V- terminals. Also test the motor that you intend to connect to the M+ and M- terminals.
Unread 02-08-2008, 04:27 PM
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
The motors all seemed to have the same resistance between them, so there isn't a short in the motors. We tested each motor individually on an older speed controller. They both worked going through a 20 AMP breaker (just in case there was a problem with too much current). We then wired it back up the same we had it (through the 40 AMPs) and its all working fine now. Although we're still not positive what the problem was.
Thanks for everyones help.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 02-08-2008, 05:42 PM
Patrick, I don't call it fixed until I have a "smoking gun". Something was wrong, even if it was a broken Victor that was replaced with a broken Victor. Keep looking. Murphy's law says it will go bad again on the final match on Einstein.
Unread 02-08-2008, 05:51 PM
Running Riot
AKA: Patrick Cloke
I never said it was fixed, just that it seems to be working fine now. We're still going to investigate the problem, but we had to leave the shop today. We're going to contact IFI and see if its possible it was a speed controller. We're also going to check every crimp and connection, make sure that nothing could have shorted, etc.
We haven't given up yet...
FIRSTsearch
Problem with our Victor? nedpirates Electrical 28 02-19-2008 07:11 PM
Victor 884 Problems Team 135 Electrical 12 02-05-2008 01:24 PM
Using a switch with a victor J. Stofflett Programming 3 01-30-2006 09:00 PM
Victor problems quickie25 General Forum 2 02-18-2004 07:51 PM
Victor control with Edurobot?? Bob Steele Motors 4 02-19-2003 12:48 PM
