Go to Post Our behavior – both good and bad – is contagious. Set a good example, behave in a mature, reasoned, professional manner and we will find that others around us will too. - dlavery [more]
Unread 07-02-2008, 01:46
AKA: Dr. Brooks
no team (WRRF)
Re: Using the IR
Your best bet would to be referencing the ground of the IR board directly to the ground of the digital inputs by connecting it there at the ports that you connect the signal pins to. One wire then runs to a 12 volt supply panel.
Unread 08-02-2008, 18:32
Amisca Amisca is offline
FRC #0538
Amisca is an unknown quantity at this point
Re: Using the IR
Could anyone give me link to http://johnmchilton.com/FIRSTIR.pdf at another site? I am looking into how to wire the IR board to the bot, but that site for some reason is blocked at our school.
Unread 08-02-2008, 19:38
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Re: Using the IR
The IR board manual is still on the FIRST website, there are no links to it anywhere I can find. The URL on the card that came with the board still works, and the page has a link to the IR board manual. I just happen to have that card in my pocket, so…
www.usfirst.org/frc_decgift
Direct link to the PDF:
http://www.usfirst.org/uploadedFiles/Community/FRC/FRC_Documents_and_Updates/2008_Assets/FIRSTIR%20-%20Instructions%20_121007.pdf
Unread 13-02-2008, 01:47
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
Re: Using the IR
do I have to use two wires each for both ground and power? or can i just use the wires that correlate to pin 1 and 3 ?
thanks
Unread 13-02-2008, 02:08
AKA: Dr. Brooks
no team (WRRF)
Re: Using the IR
thanks
There is no requirement to use two power and two ground
connections. Also, according to team updates, you can modify
the board to run off of the 5 volt rail by removing the voltage
regulator and installing the jumper across the pads provided for
this purpose. By doing this the power and signal wires can terminate
on the digital input rail of the RC with no extra wiring to the 12
volt supply.
Eugene
Unread 13-02-2008, 09:31
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Re: Using the IR
[quote=eugenebrooks;697894] Also, according to team updates, you can modify the board to run off of the 5 volt rail by removing the voltage regulator and installing the jumper across the pads provided for this purpose. By doing this the power and signal wires can terminate on the digital input rail of the RC with no extra wiring to the 12 volt supply.
If I understand what you are saying, there may be a problem with your recommendation. We looked up the PWM digital output capacity and it could source 8 ma of current. From memory, the IR LED was configured with a 470 ohm resistor, so it uses 10ma. The IR board, when activated, flashes a LED. You will then exceed the 8 ma sourcing capacity and experience ?? .
My recommendation is rather than modifiying the IR board and removing the regulator to keep the 5V regulator
and wire it to +12V panel.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Using the IR Receiver on the Robot LG67 Control System 1 06-01-2008 01:42
Where do I begin to get the robot to move using the camera? Ianuser Programming 10 16-02-2007 17:55
Using the extra buttons on the joystick. Code\\Pilot Programming 7 04-12-2004 19:30
Rules for hanging, using a loop over the end of the bar caffel Rules/Strategy 10 04-06-2004 15:04
Is Anyone Using Motors to Hoist themselves off the platform on the bar? xxlshortys Motors 36 25-02-2004 01:06
