Go to Post Insanity is overrated. - MissInformation [more]
Unread 08-02-2008, 19:42
Pneumaticsman's Avatar
Pneumaticsman Pneumaticsman is offline
AKA: Mitch guzman
FRC #1566 (Ammoknights)
Pneumaticsman will become famous soon enoughPneumaticsman will become famous soon enough
Send a message via MSN to Pneumaticsman
Ribbon cable
can we use Ribbon Cable from an electronics store, such as Radio Shack?
Thanks
Unread 08-02-2008, 19:43
in between teams
AKA: Luke Van Oort
Re: Ribbon cable
That depends, what do you want to use it for?
Team 1219: 2009 - Mentor
Unread 08-02-2008, 19:57
AKA: Mitch guzman
Re: Ribbon cable
sensors and encoders.
Unread 08-02-2008, 19:59
Re: Ribbon cable
Guess what?
<R71> Ribbon cable smaller than 24 AWG may be used to connect signal lines to the 9-pin ports on the Robot Controller.
That does appear to be the only place you can use it, though.
Unread 08-02-2008, 20:00
in between teams
AKA: Luke Van Oort
Re: Ribbon cable
It has to be 24AWG or larger (unless going into the serial ports as Eric mentioned above); if it meets that requirement, it is legal. BTW, the answer to this question and many others can be found (probably faster too) in the robot section of the manual.
Ribbon Cable emusteve Electrical 6 13-01-2006 16:33
Ribbon cable sources. Rickertsen2 Electrical 9 19-01-2004 16:23
Ribbon Cables for Digital Input Caleb Fulton Electrical 5 06-02-2003 08:39
CABLE BOOTY BURGLAR OCCRA 2 30-09-2001 13:10
