Go to Post 4 is kind of like 5 - Jaine Perotti [more]
Unread 09-02-2008, 00:18
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Re: Analog-to-digital conversions
A 1 second delay does not sound normal.
If you are using these for limit switches, you will likely need a pullup resistor (something like 4.7k should work) to 5V, as I don't believe the analog ports have any pullup within the RC like the digital ports do, since a switch works in an open-drain configuration rather than driving rail to rail.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Digital to Analog Converters 6600gt Programming 11 08-02-2007 23:27
Digital to OI Analog marcan Control System 33 05-02-2007 12:46
Accelerometer: Analog or Digital? psquared Programming 2 10-02-2005 16:38
Analog / Digital IO Connectors Aidan F. Browne Control System 4 06-02-2005 22:26
Analog vs Digital inputs? f22flyboy Programming 8 08-11-2002 22:18
