Go to Post A solution will present itself, all you have to do is be ready to take advantage of it when it does. - James1902 [more]
Unread 09-02-2008, 09:20
Tds123's Avatar
Tds123 Tds123 is offline
There is no I in team =]
AKA: Timothy Shub
FRC #1396 (Pyrobots)
Tds123 is an unknown quantity at this point
Send a message via AIM to Tds123
NEED HELP WITH uncontrollable pneumatics
OK guys! here is the deal, here i will give u a picture of our setup.... battery to generator, to 4 tanks, to regulator, to single solonoid, to double solonoid, then to piston the piston is connected to our arm and we use the single solonoid to control how much it goes up and down, which works fine by the way , we can control it completly but thing is the arm is way to floppy i can put my finger on it and the arm will go down any suggestions??? or ideas on why this maybe happening?
ThE sCaLeS oF bAlAnCe (Team 1396)
Unread 09-02-2008, 09:29
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: NEED HELP WITH uncontrollable pneumatics
how big's your piston? maybe your problem is that you do not have enough pressure. at 60 psi, most pistons are pretty solid.
Does it always do that? maybe you have a leak?
wierd, Vivek
"we don't build robots, we build people"
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
See my post in this thread
http://www.chiefdelphi.com/forums/sh...threadid=63558
Good luck! you still have a week to figure it out....if you post some pictures of the robot, we might be able to suggest some ideas.
Unread 09-02-2008, 09:37
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Which double solenoid you using??
For the SMC the aluminum operating pressure is 20 PSI and the FESTO 30 PSI
What do you have the regulator set at???
I know at least with the FESTO that if you don't have a supply pressure of 30 PSI that it goes into a neutral state and the cylinder will not extend. What most teams do is regulate the exhaust off the solenoid. Check out the thread in squirrel post
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 09-02-2008, 11:01
Tds123's Avatar
AKA: Timothy Shub
the regulator is set at60 so i guess by the time the arm goes up it loses 20 psi , so it is at 40 psi and my finger pushes it... and thanks to everyone that posted , well worth my time of finding how to post a thread which took me 1 hour to find and please post mmore suggestions
Unread 09-02-2008, 11:18
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Also, remember that pneumatics works on compressed air... When you put your finger on your arm, the force you exert is greater than it was before, causing the air in the piston to compress and move down. Try using a larger diameter piston or moving your piston to the outer part of your arm.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 11-02-2008, 04:34
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
If you are trying to control the length of a cylinder you want a "center off or center closed" solenoid. Instead of the spool inside moving and staying in position to supply air to port A or port B, when it gets power only momentary to allow air into port A or B allowing for small adjustments of a cylinder. As stated above this can be tricky since the air in the cylinder isn't the full regulated pressure but an average and can act like a spring. If you are interested in these contact SMC and they can help you select the proper one for your situation.
NEED HELP WITH WHOLE PNEUMATICS Reaper40 Pneumatics 2 17-02-2007 21:23
Need help with joystick. Team 849 Programming 1 06-02-2007 17:31
Need Help With General Pneumatics Ryan O Programming 7 24-01-2007 21:31
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
Need help with C++ Tton Programming 7 04-11-2003 19:15
