Go to Post i have a feeling that the field with be the same as it was last year just to save some money. but what is inside the the field will be diferent. - Michael Leicht [more]
Unread 09-02-2008, 09:47
FireJet FireJet is offline
AKA: Jero Sutlovic
FRC #2386 (Trojans)
FireJet is an unknown quantity at this point
2008 Gyro Code
Hi. I'm using Kevin's new 2008 code, but I can't figure out how to get the Gyro working in either autonomous mode or user mode. I believe that I set up the code right:
void Teleop_Init(void)
	Initialize_Gyro();
	if (Get_Gyro_Bias_Status() == GYRO_BIAS_NOT_DONE)
		Start_Gyro_Bias_Calc();
		while (t2 < 76)
			printf("Calculating gyro bias. State: %d.\n\r", Get_Gyro_Bias_Status());
			//Start_Gyro_Bias_Calc();
			t2++;
		Stop_Gyro_Bias_Calc();
		printf("Gyro bias calculated: %ld.\n\r", Get_Gyro_Bias());
void Teleop(void)
    	Process_Gyro_Data();
	tmpangle = Get_Gyro_Angle();
	printf("Gyro Angle %d\n\r", tmpangle);
But unfortunately, the only output I get is "Gyro Angle 0". I'm sure I've got the gyro connected right, as I get values from Get_Analog_Value (and they change), but I don't get anything from Kevin's code. Can anyone help?
Gyro code problem AMIRAM Programming 10 23-01-2006 04:26
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
gyro code odin892 Programming 2 08-04-2003 14:50
Gyro Chip Code archiver 2001 4 24-06-2002 00:57
