Go to Post They are "Human Dream and Inspiration Enablement Devices" but since that takes too long to say and explain I use the word "robot". - Foster [more]
Unread 06-02-2008, 21:29
Gherkinman's Avatar
Gherkinman Gherkinman is offline
Native German Pickle
AKA: Odin All Father
no team (Thor)
Rookie Year: 1342
Gherkinman is an unknown quantity at this point
Send a message via AIM to Gherkinman
Work Plane Visibility
Is there a universal option to hide all the work planes/axis/points in an assembly? Somtimes I make them invisible and save an .ipt but when I place it into the assembly the planes are visible and I can't make them invisible from the assembly browser.
Unread 07-02-2008, 08:20
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Re: Work Plane Visibility
From the View pull-down menu Object Visibility>All Workfeatures. uncheck or uncheck Workplanes
You might want to create a custom toolbar for this.
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Unread 09-02-2008, 10:00
Gherkinman's Avatar
no team (Thor)
Rookie Year: 1342
Thank you for your help
First Question: Work Plane Molten Pro ENGINEER / Creo 3 21-11-2007 08:12
Ball Visibility zachriggle Technical Discussion 3 20-02-2006 02:59
LED Visibility Cory General Forum 3 15-03-2004 02:13
Visibility Pete Lloyd General Forum 3 05-01-2003 23:43
visibility Tyler Olds 3D Animation and Competition 0 12-03-2002 16:14
