Go to Post The low bar will make your electronics team cry. - Joe G. [more]
Unread 09-02-2008, 10:32
Sykan's Avatar
Sykan Sykan is offline
Lead Programmer
AKA: David
FRC #0540 (Team 540)
Sykan is on a distinguished road
Re: KOP Gear Tooth Encoder Trouble
I don't think it's my printf statement because I'm using kevin printf. and it's a con. zero.
The printf statment I made was to read the rc dig itself so I see if the variable is changing and since it's a dig input it can only change 0 to 1 and back again.
the pwm connected is connected correctly.
Any other guesses?
Unread 09-02-2008, 11:20
Any other guesses?
It takes longer to print a single character then the time the gear tooth sensor's output is 1. The chances that you would actually catch the output high is very low.
If you follow Alan's post about how to print a long, you should see it counting up.
Make sure you aren't using the bad board too. Read this post: http://www.chiefdelphi.com/forums/sh...ad.php?t=62856
Unread 09-02-2008, 11:26
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
It could also be the problem that teams have been experiencing with the KOP gear tooth sensors. We connected both of ours up (one good, one bad) the good one worked fine, the bad one gave us a value of 1 after moving it for a while.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 09-02-2008, 11:39
fabalafae's Avatar
fabalafae fabalafae is offline
Guardian of the Grimmerie
FRC #0540 (TALON)
fabalafae is an unknown quantity at this point
The printf works now; it wasn't the long int problem, it was something else. But anyway...
The encoder printf is now remaining stable at 2560 and fluctuating to 768 every few times.
And also it's the good encoder, not the bad one.
We have a big code problem: it's putting out 2560 and 768 and 0 and 5 (and other miscellaneous random values) WITHOUT as well as WITH the encoder connected...uhm...
Any ideas? Please?
I am stricken and can't let you go
When the heart is cold, there's no hope, and we know
That I am crippled by all that you've done
Into the abyss will I run
Unread 09-02-2008, 11:45
RyanN's Avatar
RyanN
What version of Kevin's code are you using? We've had no problems with his code so far except stuff we did wrong. Make sure you have read the README's, as there are more steps to getting the sensors to work than you would think. We're using the version made for 3.0, and I really like it. Some things are simpler than I thought, like the Get_Analog_Value() function, all you have to do is put a number in... very simple. I would recommend using 3.0 if you're not using it already.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 11-02-2008, 11:39
fabalafae's Avatar
FRC #0540 (TALON)
We're using the latest version of Kevin's code- and we downloaded it again, just to be sure. Yeah, the encoders still don't work.
I don't know what else we can try, but I guess we'll still be working on finding the problem this afternoon after school.
Gear Tooth Sensor marco_alchemy Electrical 7 06-02-2008 09:54
Shaft encoder in KOP transmission? MrForbes Electrical 7 24-01-2008 11:40
Gear encoder code Demothesis Programming 8 20-07-2007 17:15
Gear Tooth Sensor Trouble cprogrammer Programming 1 24-01-2006 13:48
Turning a gear-tooth sensor into a quadrature output encoder Jared Russell Programming 4 18-01-2006 22:19
