Go to Post If you can spare 2 minutes (And I know you can, because the season’s over and you’re STILL on Chief Delphi) - LVMastery [more]
Unread 09-02-2008, 10:53
Re: 2008 Gyro Code
Process_Gyro_Data() should be called in a spin function, as it needs to process the data after each interrupt and the telop function isn't fast enough.
		Start_Gyro_Bias_Calc();
		while (t2 < 76)
			printf("Calculating gyro bias. State: %d.\n\r", Get_Gyro_Bias_Status());
			//Start_Gyro_Bias_Calc();
			t2++;
		Stop_Gyro_Bias_Calc();
The bias calc should last for several seconds. This starts the gyro bias calc, runs the while loop very quickly, and then stops the gyro bias calc too soon.
You should start the bias calc when t2=0, change your while loop to an if statement (so it gets called once each time through telop()) and stop it when t2=76 (or higher, since longer is better). You might also want to consider a delay so that the bias calc doesn't start right away, for everything to stabilize.
Kevin has an example of all this in the ifi_frc_sensor project.
Gyro code problem AMIRAM Programming 10 23-01-2006 04:26
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
gyro code odin892 Programming 2 08-04-2003 14:50
Gyro Chip Code archiver 2001 4 24-06-2002 00:57
