Go to Post Toughboxes are -- wait for it -- really Tough! - JesseK [more]
Unread 05-02-2008, 19:31
ShotgunNinja's Avatar
ShotgunNinja ShotgunNinja is offline
Programming Mentor, FRC 4247
AKA: Nicholas Iannone
FRC #4247 (CougarBOTS)
ShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the rough
Automated Air Compressor code
In case anyone needed some help with putting on an automated air compressor, here is some code that may be able to help. In order to use this, you would need a single pressure switch attached to a relay and an input, and a relay for the air compressor.
In Initialize:
InitPressureSwitch(psInput, psRelay);
And in a new function:
void PressureSwitch(void)
   unsigned char pswitch;
   pswitch = GetDigitalInput(psInput);
   if (pswitch)
      SetRelay(airpump, 1, 0);
   else
      SetRelay(airpump, 0, 0);
You also need to appropriately set the values of airpump, psInput, and psRelay.
Team #2970 Alum
Team #1652 Alum
2006: School Mascot for Team 1652
2007-2008: Programmer for Team 1652 (Robot Mafia)
2009: Programmer on Team 1652 (Robot Mafia), Programmer on Team 2970 (eSchool eBots)
2010-2016: Volunteer, Wisconsin Regional
2017: Programming Mentor, FRC 4247 (CougarBOTS, Obama SCTE, Milwaukee, WI)
Unread 05-02-2008, 22:03
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Automated Air Compressor code
You don't need both you only need to call InitPressureSwitch(psInput, psRelay); in the Initialize function.
It will take care of everything after that.
Unread 09-02-2008, 10:58
Well, the point is not only to set up a pressure switch, but to get that pressure switch to trigger an air compressor to activate, filling up our tanks if the pressure is too low.
If that IS what the InitPressureSwitch function would do, then please feel free to let me know, and I'll fix my code.
Team #2970 Alum
Team #1652 Alum
Unread 09-02-2008, 11:21
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Why not use the KISS method (Keep it simple silly!)
relay08_fwd != rc_dig_in18;
relay08_rev = 0;
It uses less memory, and doesn't cause the program to jump to another section of the program.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 11-02-2008, 08:41
Kingofl337's Avatar
AKA: Adam
The function of InitPressureSwitch is to turn on the compressor when the air pressure falls below the maximum air pressure as indicated by the pressure switch.
Unread 11-02-2008, 10:48
That sounds both confusing and unhelpful. First, shouldn't it turn on the compressor when the pressure falls below the minimum? The pressure switch doesn't give a "falls below maximum" indication. Second, you still haven't made it clear whether InitPressureSwitch has to be called regularly in order for it to work, or whether the single call in the Initialize function will set up some hidden background code to handle the compressor automatically without any further user action.
Naming it beginning with "Init" implies that it is intended to be run only once, at the start of the program. The name also implies that it initializes things that need to be processed later, but there doesn't seem to be an associated "ProcessPressureSwitch" function. Perhaps the tutorial explains the proper use, though I don't recall seeing anything about it.
Unread 11-02-2008, 12:04
Kingofl337's Avatar
AKA: Adam
From the help file....
Use the Pressure Switch block to automatically regulate a compressor in a pneumatic system.
The Pressure Switch function should be called a single time prior to your use of the compressor in a pneumatic system. The best place to use this block may be in 'Initialize'. The function will automatically monitor the state of the pressure switch (every 500ms), and will activate the spike to power the compressor whenever the pressure switch closes (at about 95 psi). The compressor will stop when it reaches it's maximum pressure of 115 psi.
edit: Also Alan if you read my earlier post
You don't need both, you only need to call InitPressureSwitch(psInput, psRelay); in the Initialize function.
My post you quoted made more sence.
Unread 12-02-2008, 08:14
jonboy jonboy is offline
Engineer/Mentor
FRC #0885 (The Green Team)
jonboy is an unknown quantity at this point
I assume that the pressure switch should be wired between DIO SIG and GND for the EasyCPro InitPressureSwitch() function to work correctly. Correct?
... jon
Unread 12-02-2008, 09:48
AKA: Brad
#0190 ( Gompei and the Herd)
The InitPressureSwitch function causes the timer interrupt service routine to read the pressure sensor every millisecond (probably overkill, but it was an easy place to put it). If the pressure is low the supplied relay port will be turned on, and if it's high it will be turned off.
So you only need to call the function once, and for the rest of your program, both autonomous and operator control the compressor will operate on its own.
Brad Miller
Robotics Resource Center
Unread 13-02-2008, 23:28
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
We are having problems with ours also....
We tried the code:
relay07_fwd != rc_dig_in07;
relay07_rev = 0;
and the pressure switch is connected to digital input 7 with the signal on one side of the switch and ground on the other side of the switch, the spike controlling the compressor (spike 7) is on all the time and the air compressor will continue pumping until after I disconnect it at 125 psi... it should shut off at 120 I thought but when I connect an ohm meter to this switch, it is open regardless of the air pressure (< 90 or > 120)...
I thought I read that the presure switch is normally closed but opens when the pressure dips down below 90 psi and then remains open until it reaches 120 psi... is this correct?
Is this a bad pressure switch or is there something that we don't have connected correctly?
Thanks
Unread 14-02-2008, 11:44
The code you posted is for MPLAB, while this is a sub-forum for EasyC Pro discussions.
It sounds as if you are wired correctly, so concentrate on the behavior of the pressure switch first, but test it in isolation.
Disconnect one of the pressure switch terminals so there is no possibility of a short along the wire or grounded through the RC.
Then take a ohm measurement of the pressure switch with your multi-meter when there is no pressure in the system, then allow the system to run up to 120psi and take another measurement.
If there is no change then it's the pressure switch, otherwise...
reconnect the pressure switch, but disconnect the cable from the RC, and repeat your measurements at the RC end of the cable.
Work step-by-step on narrowing down the possibilities.
Unread 14-02-2008, 12:48
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
For EasyC Pro, we just have InitPressureSwitch(18,8) in the Initialize section of project. 18 for Digital input 18, Relay 8.
Unread 14-02-2008, 15:52
Yeah... oops. Disregard my original post.
I guess that this did serve one purpose: To give people a place to go to figure out similar mistakes.
Team #2970 Alum
Team #1652 Alum
AIR COMPRESSOR !!! edgar_amaro Pneumatics 11 05-02-2008 00:43
Air Compressor Question Jrocklz Pneumatics 4 17-01-2008 21:36
Air Compressor Wireing question Bochek General Forum 7 11-01-2007 21:34
Off robot air compressor sanddrag Rules/Strategy 52 11-01-2007 15:11
Air Compressor geo Technical Discussion 4 06-02-2002 22:52
