#346
Re: New C18 3.0+ Compatible FRC Code
-Kevin |
#347
How many folks out there are using this code with MPLAB IDE v7.20 and MPLAB C18 2.4? I noticed a comment in encoder.h as follows:
This version is compatible with Microchip C18 3.0+ only Is this still true? |
#348
-Kevin |
#349
That's what I had guessed, thanks for clarification. Note that this comment also appears in at least one other file as well (interrupts.h), possibly others, too.
#350
Another ADC and Gyro question
![]() We want to use the gyro as well as other analog sensors. It appears that using Process_Gyro_Data() in Teleop_Spin(), for example, will check for ADC result count, read the ADC gyro channel only and then reset the ADC result count without reading any other ADC channels. Is that a problem? The 2007 Process_Gyro_Data() didn't check for ADC result count or do a reset inside the function, so we read our other channels just after Process_Gyro_Data() and before the reset. Where should ADC channels for our other sensors be read? Do they need to be read in the fast loop at the same time as the gyro channel is read? (Should we insert more Get_Analog_Result()s in Process_Gyro_Data to read the other channels?) We're using pots with a PID to control steering etc., and ultrasonic sensors. Thanks... |
#351
-Kevin |
#352
Lynn (D) - Team Voltage 386 Software |
#353
And I've been remiss in sending "Thanks" to Kevin, but our software group is LOVING the new code format. It is much more understandable than the earlier default code.
One change we've made is to add a few "always" functions. We hooked them in to the main program and they're called "Always_Spin", "Always_Before", and "Always_After". They get called regardless of the current operating mode. The *_Before and *_After routine get called before and after the invocations of the mode's command packet processing routine. We did this after we found ourselves adding the same invocations to Disabled_Spin, Teleop_Spin, and Autonomous_Spin for the third time. Always_Spin makes it easy. Always_After is a handy place to get a last chance to reverse any PWM values for opposing drive motors without having to remember to do it everywhere else. Positive logic rules with the ability to override it for reality where necessary. (Robots shouldn't go forwards when you set PWMs to 0, but when mechanical mounts opposing motors and controls wants red to red to positive consistency, it falls to software to make it all work right). Lynn (D) - Team Voltage 386 Software |
#354
-Kevin |
#355
I'm having trouble with the Gyro bias calculation in the code posted on 2/2. If I use the previous code (without the circular buffer), I get a gyro bias of ~2080. With the newer code, I get a gyro bias of ~1660. This make the code think the gyro is spinning continuously. Is there an OBO (off by one) error lurking somewhere? Is anyone else having problems with the updated code?
#356
btw
I had a problem, I was trying to declare a variable in "interrupts.c", and use it also in "autonomous.c," no matter what i've tried, it didn't work (nope, trying to redeclare it as an extern in the header didn't work either), strangely enough, after wasting an hour like an idiot ,I've declared it in autonomous.c and it worked like a charm. incredibly weird.. |
#357
Kevin
What is the difference in master code from the 2007 controller and the 2008 controller... is there a procedure to update a 2007 controller to the current master code?? I understand that the hardware is 100% the same... thanks... |
#358
http://www.ifirobotics.com/docs/frc-master-ver15.zip You use the IFI loader to send it to the robot controller (the boot loader intercepts it and sends it to the master). -Kevin |
#359
Kevin,
We just uncovered (and fixed) a potential gotcha in the invocation of Teleop_Init() from main. We tried to access the current state of the OI inputs from there and they weren't available! We found that the Getdata() call was occurring AFTER the Teleop_Init(). We moved it BEFORE the if(teleop_init_flag) test and it corrected our problem. On further inspection as I'm writing this, the same issue would plague the other two *_Init() invocations. Simply moving the Getdata call will make the current OI data available to those functions. Lynn (D) - Team Voltage 386 Software |
#360
Edit: I'll change it when I make the changes mentioned above, but I don't see where this could cause a ploblem as the OI data from the previous Getdata() should be valid. What problem were you having? -Kevin -Kevin Last edited by Kevin Watson : 09-02-2008 at 23:59. |
| Does the camera code suits to all versions of MPLAB and C18? | razer | Programming | 3 | 04-01-2007 14:50 |
| Trying to follow C18 interrupt context code... | dcbrown | Programming | 5 | 21-12-2006 09:01 |
| Error w/ FRC code | JamesBrown | Programming | 2 | 08-01-2005 16:17 |
| Programming code Fix FRC | Ferazel2001 | Programming | 6 | 08-02-2004 02:46 |
| FRC default code | hedgehogger | Programming | 2 | 21-01-2004 18:41 |
