Go to Post "The only constant is change" is a hint that probably applies to every season of FIRST. - Chris is me [more]
Unread 09-02-2008, 11:34
CyDrive's Avatar
CyDrive CyDrive is offline
FRC #1203 (pandemonium)
CyDrive is an unknown quantity at this point
Help with mecanum wheels
We recently purchased the mecanum wheels and have tried different ideas to get all the motors to spin at exactly the same speed at time. We have tried a bias but that didn't work due to the increase or descrease in our margin of error over time. I have searched the forums and have yet to find anything we could really use. If anyone could help it would be appreciated.
Unread 09-02-2008, 12:51
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Re: Help with mecanum wheels
You could use geartooth sensors to monitor the changes and adjust the speed accordingly. I know we have used this for autonomous in the past.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 09-02-2008, 13:03
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
I'd recommend a PID for velocity. You'd set up one for each wheel, and then just change the target values every time you needed too, I suppose. Or maybe just for autonomous, as trying to brake wouldn't work...
Anyway, there are a couple of whitepapers on PID you can use, and I know Kevin Watson has PID for velocity already made and ready to go. They work very well if you can use them.
Unread 09-02-2008, 16:05
3dude_2231's Avatar
3dude_2231 3dude_2231 is offline
no one messes with a Thingy =|
AKA: Menscher,Ran Menscher =]
FRC #2231 (Onyxtronix)
3dude_2231 is a jewel in the rough3dude_2231 is a jewel in the rough3dude_2231 is a jewel in the rough
Send a message via MSN to 3dude_2231
we had the same prob, too.
here's what you should do:
* if your using motors from different years, place them in a logical order,
for example: 2 08s in the front, and 2 07s in the back.
* grease the gears evenly, and don't be cheap =]
* calibrate the Victors
* use wide and even cables between Victors and fuses, just in case
* make sure, and you better be real sure your joystick is calibrated and trimmed
and your code is correct.
Redefining the word "Rookie". (for 2 years now..)
Israeli Off Season Games: WINNERS!
check out this cool project I'm into..
Unread 09-02-2008, 16:36
manderson5192 manderson5192 is offline
AKA: Matt Anderson
FRC #0948 (Newport Robotics Group: NRG (pronounced eNeRGy))
manderson5192 is on a distinguished road
My team had the same issue as well. We used one encoder to get RPM data for every PWM value and produced a graph of this data. Using this graph we were able to see which victor/cim pairs were consistently faster and where the respective "true" dead zone of pwm values were for each victor. We immediately saw the dead zone ended up centered at 133, not 127. By shifting all PWMs up by six and limiting PWMs so they wouldn't overflow the max of 254 we were able to get a nearly perfect strafe.
Something you might also consider is using encoders, gear tooth sensors, or the gyro in a PID loop.
Unread 10-02-2008, 14:30
team1203 4life's Avatar
team1203 4life team1203 4life is offline
President
FRC #1203 (Pandemonium)
team1203 4life is a jewel in the roughteam1203 4life is a jewel in the roughteam1203 4life is a jewel in the rough
Send a message via AIM to team1203 4life
yo mike what would happen if we where to wire the fl trany and the br trany to the same speed control and wire the fr trany and bl trany to the same speed controler and place a gear tooth sensors in the fl and fr tranys so they could all be regulated and fire at the same time so it would not vear off course
if it is on one of my posts it is propbly spelt wrong
Why drive around somthing when you can drive through it
Unread 10-02-2008, 16:09
CyDrive's Avatar
That would work as long as you can hook up two motors to a vicktor.
Unread 10-02-2008, 16:16
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
One of your issues you may be experiencing is the manufacturing differences in DC motors. No two motors will ever spin at exactly the same speed and unequal weight at friction will cause you to drift of course. Btw you can not wire 2 motors to the same speed controller. I would suggest to make your system as efficient as possible and then if that doesn't work either program PID or some other closed loop or get your drive to compensate for the drift. Out robot drifts to the right this year so every time i drive I always give the right joystick more of a push than the left.
-Dustin Benedict
Bumpy Ride with AM's 8" Mecanum wheels? Leav Technical Discussion 12 14-02-2008 01:16
need help about Mecanum Wheels mahmosh Technical Discussion 4 18-01-2008 11:50
Assistance with Mecanum Wheels CollmandosGrl General Forum 8 14-01-2008 17:42
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Teams With Mecanum Wheels Foss@Team176 Technical Discussion 15 06-10-2005 09:38
