Controller size limit?
Hey, I was wondering if there is a limit to the max. size of the controller, thanks in advance for the replies!
Taco. |
Re: Controller size limit?
You only get a certian space to set your controllers on. I dont know the exact dimensions though. If I find anything I'll let you know.
Joey |
Joey |
Sweet, thanks!
Yeah, does it matter what type of controller it is? For example, could we use a steering wheel from a PS2? =) Last edited by KGood : 09-02-2008 at 13:47. |
You can use that controller. In fact, any controller is legal, as long as it connects to the ports on the OI. You can put a Chicklet in between if it's a USB connector, or you can make your own connection.
| Using a limit switch to limit motion | ManicMechanic | Programming | 16 | 20-12-2007 00:54 |
| Wire Size Limit? | (InsrtNameHere) | Electrical | 2 | 15-02-2006 20:20 |
| [OCCRA]: Size limit of Operator Control Station | Alex Golec | OCCRA Q&A | 1 | 11-10-2005 05:33 |
| 32k controller limit | flounder22001 | Programming | 9 | 07-02-2005 00:01 |
| Robot Controller File Size Limit ?? | RoboGeek | Programming | 1 | 17-01-2005 19:59 |
