Go to Post You can build an amazing robot that is capable and beautiful on a limited budget. - Andy Baker [more]
Unread 09-02-2008, 14:21
sparrowkc sparrowkc is offline
AKA: Mark
FRC #1986 (Team Titanium)
sparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to behold
Spike Relay Wire Gauge
I am wiring up some Spike relays to control solenoids for our "apparatus". I don't want to waste a bunch of 14 gauge wire to do this, and I was wondering If I can put like a 5 amp fuse in the fuse block or in the relay where the 20 amp regularly is.
I have black and red 24 Gauge wire to use. What type of fuse would I have to put in for that?
Unread 09-02-2008, 14:31
EricH EricH is online now
Re: Spike Relay Wire Gauge
The answer is, you must follow the wiring rules. So NO on a 5 A fuse/breaker.
As for what fuse, you need to keep the 20A fuse in the Spike and use a 20A breaker in the panel.
(And, this may sound silly, but you should read Section 8.3.6. It has all the wiring rules.)
Unread 09-02-2008, 14:34
AKA: Mark
So how do I hook up 14 gauge wire to the festo valves with the stress relief and tiny little screw terminals?
Unread 09-02-2008, 14:38
AKA: Mark
Ok, I promise I read the rules several times before but...
<R74> ...24 AWG or larger diameter wire must be used for providing power to pneumatic valves.
Do I just use the 20 amp fuse and not worry about it?
Unread 09-02-2008, 14:43
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
You should use 18 AWG or larger from the breaker panel to the Spike and 24 AWG from there to the solenoid. That way, you're fulfilling both parts of the rule.
<R47> All main and branch circuits shall be wired with appropriately sized wire:
 12 AWG or largerdiameter wire must be used for all circuits protected by a 40A circuit
breaker.
 14 AWG or largerdiameter wire must be used for all circuits protected by a 30A circuit
breaker.
 18 AWG or largerdiameter wire must be used for all circuits protected by a 20A circuit
breaker.
 24 AWG or larger diameter wire must be used for providing power to pneumatic valves.
Unread 09-02-2008, 14:44
Yep. The 20A fuse is protected by a 20A breaker.
Unread 09-02-2008, 14:54
usbcd36's Avatar
AKA: "DOS"
The 20 amp fuse in the Spike is meant to protect the Spike itself from damage; the 20 amp breaker in the panel is meant to protect the (18 AWG) wiring from overheating.
Unread 12-02-2008, 14:26
The Spike must be fed by a 20 amp circuit breaker per R55 and Team Update 9. The robot rules state that wiring protected by a 20 circuit breaker be #18 or larger. So the Spike is fed with a #18 but can have #24 or larger wire on the output if the load is a pneumatic valve(s). The fuse in the Spike will blow open in the event of a wiring short on the output of the Spike.
Gear Tooth Sensor Wire Gauge usbcd36 Electrical 11 21-01-2008 20:41
Wire gauge vs. current AdamHeard Electrical 7 09-11-2007 10:36
Minimum Gauge Wire for Sensors? psquared89 Electrical 2 05-02-2006 15:26
Wire Gauge Question Neghman Electrical 1 14-02-2004 19:56
11 Gauge Wire...where? Matt Krass Electrical 6 21-01-2003 10:17
