Go to Post Dear CNN, We're not from indiana. Love, Wildstang - AlecMataloni [more]
Unread 02-02-2008, 10:58
Macdaddy549 Macdaddy549 is offline
Mr. Mac
#0549 (DevilDawgs)
Macdaddy549 is infamous around these partsMacdaddy549 is infamous around these partsMacdaddy549 is infamous around these partsMacdaddy549 is infamous around these partsMacdaddy549 is infamous around these partsMacdaddy549 is infamous around these parts
additional window motor
I searchd the threads, AND the manual. I am unable to determine if we are allowed to use an additional window motor on our robot. We would use the motor from the 2007 FRC kit. It looks like we just need to add this to the BOM and not depreceiate the value. Are we even able to use a total of THREE window motors?
Team 549.... thanks
Unread 02-02-2008, 11:07
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: additional window motor
You can only use the number of and type of window motors provided in the KOP. If the 2007 motor is the exact same part number, then you can use it to replace the 2008 motor, but not in addition to it.
<R59> Additional motors specifically permitted on 2008 FRC ROBOTS include:
All motors, actuators, and servos provided in the 2008 Kit Of Parts,
HITEC HS-322HD servos,
FIRST Tech Challenge (FTC) servos (Innovation First part number 276-2162),
FIRST Tech Challenge (FTC) motors (Innovation First part number 276-2163), One or two additional 2-1/2” CIM motors (part #FR801-001 and/or M4-R0062-12 in addition to those provided in the Kit Of Parts. This means that up to four, and no more, 2-1/2” CIM motors can be used on the ROBOT.
<R60> Items specifically PROHIBITED from use on the ROBOT include:
Electric motors and/or servos different from, or in addition to, those in the Kit Of Parts, with the exception of those specifically permitted by Rule <R59>.
Electric solenoid actuators (note: electric solenoid actuators are NOT the same as pneumatic solenoid valves – the latter are permitted, the former are not).
Unread 09-02-2008, 15:49
latonya latonya is offline
FRC #1371
latonya is an unknown quantity at this point
Question Need help in a hurry...two questions!!!
Can we use a 3rd (One from last year) CIM motor?
If so, what is the torque of the motor using last year's gear box?
Unread 09-02-2008, 15:53
Re: Need help in a hurry...two questions!!!
Using the motor--yes. I am not sure about the torque.
Unread 09-02-2008, 16:22
merybar's Avatar
merybar merybar is offline
AKA: Matt
FRC #0894 (Chargers Robotics)
merybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of light
Send a message via AIM to merybar
So let me ask a question then for clarification, can we use a third CIM motor for something other than the drivetrain if we only use 2 on the drivetrain?
Thanks
Unread 09-02-2008, 17:24
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
As was mentioned by squirrel (<R60>), you can use up to four CIMs on your robot this year. You can use them for anything you want, assuming they don't break any other rules.
The answer to your question is yes, you can. You could even use it for your drivetrain if you want.
Unread 09-02-2008, 21:21
merybar's Avatar
AKA: Matt
ok thanks
Window Motor Robo_Coyote Motors 5 21-01-2007 13:00
Window Motor Moonlightic Motors 1 17-01-2007 07:56
Window Motor Calvin Motors 9 21-02-2005 17:04
window motor backlash nic_radford Motors 15 14-02-2004 19:06
window motor archiver 1999 0 23-06-2002 21:52
