Go to Post ...these guys have taken it to a new level. (I want to be part of a team like that.) - Tetraman [more]
Unread 09-02-2008, 16:05
3dude_2231's Avatar
3dude_2231 3dude_2231 is offline
no one messes with a Thingy =|
AKA: Menscher,Ran Menscher =]
FRC #2231 (Onyxtronix)
3dude_2231 is a jewel in the rough3dude_2231 is a jewel in the rough3dude_2231 is a jewel in the rough
Send a message via MSN to 3dude_2231
Re: Help with mecanum wheels
we had the same prob, too.
here's what you should do:
* if your using motors from different years, place them in a logical order,
for example: 2 08s in the front, and 2 07s in the back.
* grease the gears evenly, and don't be cheap =]
* calibrate the Victors
* use wide and even cables between Victors and fuses, just in case
* make sure, and you better be real sure your joystick is calibrated and trimmed
and your code is correct.
Redefining the word "Rookie". (for 2 years now..)
Israeli Off Season Games: WINNERS!
check out this cool project I'm into..
Unread 09-02-2008, 16:36
manderson5192 manderson5192 is offline
AKA: Matt Anderson
FRC #0948 (Newport Robotics Group: NRG (pronounced eNeRGy))
manderson5192 is on a distinguished road
My team had the same issue as well. We used one encoder to get RPM data for every PWM value and produced a graph of this data. Using this graph we were able to see which victor/cim pairs were consistently faster and where the respective "true" dead zone of pwm values were for each victor. We immediately saw the dead zone ended up centered at 133, not 127. By shifting all PWMs up by six and limiting PWMs so they wouldn't overflow the max of 254 we were able to get a nearly perfect strafe.
Something you might also consider is using encoders, gear tooth sensors, or the gyro in a PID loop.
Bumpy Ride with AM's 8" Mecanum wheels? Leav Technical Discussion 12 14-02-2008 01:16
need help about Mecanum Wheels mahmosh Technical Discussion 4 18-01-2008 11:50
Assistance with Mecanum Wheels CollmandosGrl General Forum 8 14-01-2008 17:42
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Teams With Mecanum Wheels Foss@Team176 Technical Discussion 15 06-10-2005 09:38
