Go to Post If this thread isn't a sign that CD is going through some serious withdrawals, I don't know what is. - Ty Tremblay [more]
Unread 09-02-2008, 16:27
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Controller size limit?
You can use that controller. In fact, any controller is legal, as long as it connects to the ports on the OI. You can put a Chicklet in between if it's a USB connector, or you can make your own connection.
Some relevant rules. THIS is why everyone keeps saying to read the manual, because the answers to most questions are in there. EricH is correct that you can make your own connection, but it needs to follow the rules - a PDA cannot be used, for example.
<R101> The OPERATOR CONSOLE designed by the team must fit on the 60” wide by 12” deep shelf in the Alliance Station (excluding any items that are held or worn by the DRIVERS during the MATCH).
<R105> All equipment connected to the joystick ports of the Operator Interface must be powered solely through the power available through the port. External power sources of any type are not permitted on any equipment connected to the joystick ports. Portable computing devices must not be connected to joystick input ports on the Operator Interface. Power-passive
devices (e.g. joysticks that draw their power solely through the Operator Interface joystick port) are permitted.
<R106> Devices connected to the joystick ports of the Operator Interface via a FIRST-approved USB adapter (the only approved USB adapter is IFI Part Number USB-CHICKLET) are excluded from Rule <R105>. If used, this USB adapter must be powered with a 7.2V battery functionally identical to the back-up battery. Power from the competition port or any other
source shall not be used to power the USB adapter. The USB adapter must be positioned within the OPERATOR CONSOLE so that the indicator lights may be seen during inspection and operation in a MATCH.
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
Wire Size Limit? (InsrtNameHere) Electrical 2 15-02-2006 20:20
[OCCRA]: Size limit of Operator Control Station Alex Golec OCCRA Q&A 1 11-10-2005 05:33
32k controller limit flounder22001 Programming 9 07-02-2005 00:01
Robot Controller File Size Limit ?? RoboGeek Programming 1 17-01-2005 19:59
