Go to Post Good drivers know the limits of their machines, but great drivers have machines with no limits. - sanddrag [more]
Unread 31-01-2008, 01:17
Bluephlame's Avatar
Bluephlame Bluephlame is offline
Controls Leader
AKA: Joe B.
FRC #0145 (TRx)
Team Role: Electrical
Bluephlame is an unknown quantity at this point
Send a message via AIM to Bluephlame
RC remote program and reset button schematic
After fruitlessly searching for several hours on IFI's website for a schematic for a remote program and reset button, I came to the conclusion that one did not exist. But, I did find a response on the IFI Q&A forum that explained how to wire one and from that explanation, I was able to successfully wire it. I then made a schematic of it to share with you guys on this forum who have always been a great help to myself and others. Just giving something back is all...
http://www.trx145.net/photogallery/RC%20Reset%20and%20Program%20Switch.gif
<Patrician|Away> what does your robot do, sam?
<bovril> it collects data about the surrounding environment, then discards it and drives into walls.
Last edited by Bluephlame : 31-01-2008 at 21:12. Reason: Rehosted on Team 145's website
Unread 31-01-2008, 02:01
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: RC remote program and reset button schematic
Or, you can wire them to the RC's digital outputs and you can put it into program mode from your computer
Unread 09-02-2008, 16:08
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
This one sentence has changed my life. Thank you.
Now if I can just find a solution to wireless RS-232 at 115200 baud my life will be complete.
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Unread 09-02-2008, 17:48
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I'm not following.
I understand you can wire it to a RC digital out, but if you're running from the OI you'd need to have a button on the OI put it in program.
Am I missing something? Are you running the robot off the computer?
Unread 09-02-2008, 19:46
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
If the computer and the robot are connected via the program port, you can have a process running in the background of the robot controller that recognizes "commands" from IFI Loader (a la Kevin's "Bells and Whistles" code from last year).
Unread 10-02-2008, 01:24
Originally Posted by DanDon View Post
If the computer and the robot are connected via the program port,...
And if your goal is to download a program to the Robot Controller, you have to have your computer and the robot connected via the program port in any case.
A few years ago, I put together a couple of "breakout" connectors that stole three pins from the 9-pin serial cable and provided a remote reset and program button. Giving the person at the keyboard the ability to put the robot controller in program mode himself is a whole lot more convenient than having him ask someone to reach into the robot and press the button.
Last year, I got fancier and replaced the serial cable with the equivalent of an ethernet cable, putting adapters at each end. The computer side has a 9-pin female serial connector, the remote buttons, and an RJ-45 jack. The RC side has another RJ-45 jack, a 9-pin male serial connector, and a servo connector for the remote button header pins. The robot's jack was intended to be mounted in an easily accessible spot, to be more convenient than the serial program port on the RC itself.
We eventually moved beyond needing a hardware button at all. We implemented the kind of menuing system DanDon alluded to, with a single wire from one of the RC's digital outputs to the remote PROG pin. It worked so well we did it again this year, with some refinement to the menuing routines to make it easier to add new menus. I intend to work with the TechnoKats' lead student programmer this spring to make our menuing framework available for other teams to use and/or adapt.
Remote Reset/Prog through DigOut/Relay tdlrali Electrical 4 13-02-2007 12:48
FRC: Reset and Program Controls yanksrock777 General Forum 4 24-01-2007 22:37
Camera won't initialize when reset from RC - reset from OI and Power-up works, krunal Programming 7 15-01-2007 00:13
Reset Button for Vex RC's irishninja FIRST Tech Challenge 5 18-06-2006 15:56
Visibility of Robot Controller and Reset Button Tracy Rules/Strategy 1 17-02-2003 07:36
