Go to Post We were all rookies once. Some of us still are... - Wayne C. [more]
Unread 09-02-2008, 17:49
BrittanyV BrittanyV is offline
FRC #1025 (Impi Robotics)
BrittanyV is on a distinguished road
Help! I think we fried our OI!
Today we decided to finally wire our disable/ autonomous switch. We followed the schematic found here:
http://www.ifirobotics.com/docs/comp...guide-reva.pdf
(which is where other posts had led us) and when we plugged the newly made switches in, our OI stopped working. Now, only the green power light turns on when we plug it in. I had taped all the other wires on the 15-pin cable so they would not touch, so that can't be the reason our OI fried.
Also, I noticed after our OI stopped working that the schematic was from 2005, so that could be a possible issue.
Has this happened to anyone else? Can anything be done? Are we doomed? We're a new team (but not a rookie) so we don't have last year's OI, but we do have the 2006 OI. Could we use that if our OI is completely beyond repair?
Hopefully something can be done! Thanks for your help.
Unread 09-02-2008, 18:53
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
Re: Help! I think we fried our OI!
The 2005 pinout is correct. You should only have 4 wires connected to the 15 pin connector. This is the same for 2006-2008.
The diagram shows the pinout from the Solder cup side. Make sure you double check the pins.
Have you set your team number yet?. Does it work when tethered to the robot controller?
If you cannot troubleshoot the error, call IFI. Perhaps an internal protection fuse was blown due to improper wiring.
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 09-02-2008, 22:35
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
I believe the 2006 OI will NOT work with the 2007/2008 radios. If you have the redios from 2006, or eariler, then you can use those for testing. The 2008 RC WILL work with the older radios.
Give IFI a call, and see what they say.
Eric Haskins KC9JVH
Unread 09-02-2008, 23:49
Brittany,
You did not say whether you disconnected the dongle and performed a power reset of the OI. Assuming you did remove the dongle and removed power for several seconds and you still have no operation, you may have indeed fried the OI. If you cannot control the robot with the tether and nothing else seems to work, a call to IFI will get you started on the road to repair. Please check through the OI Reference Guide for more information.
Unread 10-02-2008, 12:50
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
We did the same thing with our OI two days ago. Now only the Power On LED lights up when we plug in power. This is without anything else plugged into the OI. I believe the mistake we made was wiring the connector backwards, so when we flipped the disable switch, we shorted pins 1 and 4 instead of pins 5 and 8. 1 and 4 are not labeled on the pinout, and IFI says not to connect anything to them, so it kind of makes sense why it doesn't work.
I called IFI on Friday, they said the processor was fried, and it would be $120 to repair it, so we sent it off on Friday. Luckily we still have last year's OI to practice with until we get it repaired.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 10-02-2008, 15:10
Yes, that's what we did. Thanks for the help. And by the way, the radios do actually work with the 2006 OI- thank goodness. Hopefully we'll be able to get the 2008 OI repaired.
Once again, thanks a lot,
Brittany
I have a higher and grander standard of principle than George Washington. He could not lie; I can, but I won't. -Mark Twain
Unread 10-02-2008, 21:28
AKA: Eric Haskins
I knew you could use the 2006 RC if you upgrade the master firmware, but I was sure I had read that the OI wasn't compatible.
Good to know, though.
Eric
Eric Haskins KC9JVH
We fixed our roller, Let us know what you think! Specialized Robot Showcase 8 22-02-2006 17:32
I think we found our limit .. Brandon Martus Announcements 64 04-01-2006 17:23
pic: I think our robot might be underweight ryan_f Robot Showcase 4 18-02-2005 09:31
What do you think of our banner? Munkaboo IT / Communications 4 03-03-2004 15:20
fried archiver 2000 4 23-06-2002 22:45
