Go to Post FIRST is the most glorious test of the mind. Anyone can run a marathon or get a slam-dunk. It takes guts to admit you are a nerd that enjoys six weeks off non-stop stress, and actually thrives on it. - kws4000 [more]
Unread 09-02-2008, 21:27
ldeffenb ldeffenb is offline
AKA: Lynn Deffenbaugh (Mr)
None #0386 (Team Voltage 386)
ldeffenb has a spectacular aura aboutldeffenb has a spectacular aura aboutldeffenb has a spectacular aura about
Send a message via ICQ to ldeffenb Send a message via AIM to ldeffenb Send a message via Yahoo to ldeffenb
Re: New C18 3.0+ Compatible FRC Code
Kevin,
We just uncovered (and fixed) a potential gotcha in the invocation of Teleop_Init() from main. We tried to access the current state of the OI inputs from there and they weren't available!
We found that the Getdata() call was occurring AFTER the Teleop_Init(). We moved it BEFORE the if(teleop_init_flag) test and it corrected our problem.
On further inspection as I'm writing this, the same issue would plague the other two *_Init() invocations. Simply moving the Getdata call will make the current OI data available to those functions.
Lynn (D) - Team Voltage 386 Software
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
