Go to Post FIRST isn't about money or robots... it is about people. Take care of that and the rest will follow. - dtengineering [more]
Unread 09-02-2008, 21:52
Greg Peshek Greg Peshek is offline
FLL #2054
Greg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to all
Re: Team 964's Robit Thingamabob
Any particular reason you have to do rear-wheel steering? (At least that's what I'm guessing you're trying) And why you can't make the turning wheels the front? That's what we're doing with our Ackermann steering setup. Of course you'll still have the problem of not turning quite as tight as you'd like because it's not true Ackermann steering, but it should help.
If you have the programming capabilities I would suggest putting a potentiometer on the rack to sense position. If you have really have the programming capabilities it would be a lot easier for your drivers if the wheels would center themselves when you bring the joystick back to center, instead of having the wheels move when the joystick moves from side to side (essentially making your globe motor a large servo). We had the same problem as you, it being hard to control, but we are remedying it with the situation I just described.
Hope you get it working well.
-Greg P.
pic: Team 964's 2008 Group Photo synth3tk Extra Discussion 1 22-01-2008 01:58
pic: 964's programming table synth3tk Extra Discussion 18 14-12-2007 08:39
Thank you Team 179, team 237, team 269, team 303, team 1065, and team 1251 Arefin Bari Thanks and/or Congrats 13 16-03-2006 20:52
Team in a Box V. 2 : Featuring Team 67 and Team 103 OZ_341 General Forum 7 30-01-2006 16:53
