Go to Post To put it simply: An adult coach impacts a team for two minutes. An adult mentor impacts a team for a lifetime. - dlavery [more]
Unread 09-02-2008, 22:06
commodoredl commodoredl is offline
AKA: Dan Lavoie
FRC #2877 (LigerBots)
commodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud of
Team 578 can hurdle
Today was a big day for us, the programming team got the drive code done, and the code needed to operate the motor for our hurdling device, affectionately named "the boot."
http://www.youtube.com/watch?v=tDXdFw8Stfc
Thoughts?
Unread 09-02-2008, 22:17
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Team 578 can hurdle
I like it very cool and it looks very safe.
-Dustin Benedict
Unread 09-02-2008, 22:19
AKA: Dan Lavoie
We only had one problem with it and that's that it's a bit top-heavy when we raise the boot. See here:
http://www.youtube.com/watch?v=YK8c43Irf5E
We were wondering if anyone else came up with a similar design? We saw a lot of catapults but nothing that would kick like ours.
Unread 09-02-2008, 22:28
Greg Peshek Greg Peshek is offline
FLL #2054
Greg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to all
Very interesting design, I don't think you'll end up seeing many (if any) of those kind of designs at regionals (not a bad thing, I quite like it). I think you might eliminate the "tip the robot when the boot gets to the top" problem if you put something kind of spring of softening system to stop the arm.
By the way, what does your "boot" weight? It looks like it weighs a lot, but I can't tell.
-Greg P.
Unread 09-02-2008, 22:31
dtengineering's Avatar
AKA: Jason Brett
Congratulations! I know well the cheer that rang out as it hurdled for the first time... we were up and launching (using pneumatics) from the robot for the first time this weekend, too.
We had considered an idea like this, but you are the first group that I know of to have built one... and almost certainly the first to post it to CD!
How heavy, by the way, is "the boot"?
Jason
P.S. It would look great with a real boot on there!
Unread 09-02-2008, 22:34
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
curious...very curious. This is a far cry from the 1000 lifts and catapults I've seen on CD. Very nice. My only worry is when you are reseting the boot and another team hits you from behind; possible tip hazard. Aside from that very cool.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 09-02-2008, 22:48
rjmah rjmah is offline
rjmah will become famous soon enough
I wonder how sticky they'll be about the 80 inch cylinder rule. My guess is that you exceed it if your forks are extended and the boot is resetting at the same time. While you can tell them the normal operating sequence won't exceed it, during the heat of the game you can't guarantee it won't happen.
Robert Mah
Team 1246 Agincourt Lancers
Unread 09-02-2008, 22:51
FTCmisfit FTCmisfit is offline
AKA: FTC 232
FRC #0011 (M.O.R.T.)
FTCmisfit is infamous around these partsFTCmisfit is infamous around these parts
Cool Re: Team 578 can hurdle
Very interesting idea.it looks effective, does it work consistently? Can your drive train maneuver well?
-Misfit
Unread 09-02-2008, 23:00
AKA: Dan Lavoie
Right now the boot weighs 12 lbs at the end. We'll also be weighing our robot down for better stability.
That's a good point, we extended and checked and we're around 78.5 inches.
As for working, it will shoot every time, we only have problems trying to pick up the trackball with our forks, that's something we're going to try to improve before the 19th.
Our drive train, I haven't seen much more than a few seconds of it maneuvering, but we were going cautiously to make sure we could pick up the ball. I don't know what our top fps is right now.
Unread 09-02-2008, 23:19
Nice work! It probably helps that you hug the ball to the carriage.
Robert Mah
Unread 09-02-2008, 23:25
sovereign sovereign is offline
AKA: Patrick Morabito
FRC #0578 (Blue Lightning)
sovereign is an unknown quantity at this point
Send a message via AIM to sovereign
We have a new traction system implemented in our drive train, so it's quite effective. The boot can be stopped mid-swing so it's also safe. I took several videos myself, but haven't gotten them to our media subteam yet.
Unread 10-02-2008, 02:10
RIT_FIRST_LH RIT_FIRST_LH is offline
FIRST Rochester
AKA: Larry Herb
Team Role: Marketing
RIT_FIRST_LH will become famous soon enoughRIT_FIRST_LH will become famous soon enough
I'm very impressed, I didn't think the boot was going to work as well as it did. Nice job.
Unread 10-02-2008, 02:15
Drwurm's Avatar
Drwurm Drwurm is offline
Electrical Alumni
AKA: Jason "Powercoach" Osmann
Drwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of light
Send a message via AIM to Drwurm
Now that design might just win you an innovation award, very very creative.
Also, I was thinking, instead of using a 12 pound weight, you ought to just use your battery
Electrical Engineer (in training)
Also grows carnivorous plants.
BEACH CITIES ROBOTICS:
2007 FTC "Quad Quandary" World Champions
Unread 10-02-2008, 06:29
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Very interesting and creative.
Doug Leppard
Unread 10-02-2008, 07:22
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Looks neat and safe.
One question though. Have you tried it with a slightly deflated ball? Some teams have noticed that the balls inflation varies with temperature.
Hope you have a great year.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
reverse hurdle. Stillen General Forum 5 06-02-2008 19:59
Hurdle Question Vanquish General Forum 2 09-01-2008 10:36
Can you hurdle the Trackball's backward? Sila741 Rules/Strategy 14 08-01-2008 02:30
Team 578 Blue Lightning's Website 007! (Click_Here) Website Design/Showcase 6 19-03-2007 16:43
Team 97 thanks teams 578 and 1725! ZZII 527 Thanks and/or Congrats 1 28-03-2006 23:05
