Go to Post Wow, 4 pages of arguments over water...... Is it the off season or what? - Botsup [more]
Unread 09-02-2008, 12:42
schmidtz schmidtz is offline
FRC #2518
schmidtz is an unknown quantity at this point
HELP!!! question about inspection
our robot has a metal cover over the entire electronic/motor/gears/everything. we need to know whether or not we will have to take it off for inspection because right now it is riveted to the frame. we could take it off with some force and about 2 hours of work, but we really dont know if it is necessary.
Unread 09-02-2008, 12:46
Re: HELP!!! question about inspection
Can you see the RC from three feet in front of the robot? Can an inspector see the breaker panels? Pneumatics? Motors?
If the answer to any of those questions is "No", you will need to at least modify it to allow for seeing through it. Especially the controller; you can't compete at all if you can't see it.
Unread 09-02-2008, 12:49
FRC #2518
the top is hinged so that people can see into it and mess with stuff but being as it is made of metal you cannot see the stuff when the top is closed
Unread 09-02-2008, 12:51
Hinged so you can see in will probably fly at inspection...but the IFI folks are going to have a hard time seeing the RC through metal. You could probably cut a section out and put lexan or something of that sort in so the controller can be seen.
Unread 09-02-2008, 13:24
FRC #2518
here are the pics:
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Unread 09-02-2008, 13:43
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
I recommend you replace those top metal panels with Polycarbonate (Lexan, etc). That should be sufficient to pass inspection and keep them visible pre-match.
Unread 09-02-2008, 14:07
Yeah... You look like a BattleBot with all that metal. The top should be Lexan; more than that probably won't be necessary to change. (And it's a relatively quick change--get the metal off, and then use virtually the same attachment to put the Lexan on.
Unread 09-02-2008, 22:01
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
You do need to put a window in the top. It should be strong enough. Very nice skin though!
Unread 09-02-2008, 23:01
dtengineering's Avatar
AKA: Jason Brett
You may want to check out your radio range, too. The radios are usually pretty good... but you have placed yours inside a big conductive box!
If you don't want to pull the "lid" from your robot, you could cut a window in in and cover the window in with lexan so that you can see the RC from 3' in front of the robot when it is in it's starting configuration.
I like the look of this machine, though!
Jason
P.S. If you haven't already done so, don't forget to think about how you will access various components for repair during competition.
Unread 09-02-2008, 23:32
I agree with the posts thus far and to reiterate...
<R72> The Robot Controller must be positioned within the ROBOT so that its indicator lights can be seen during inspection and when standing three feet in front of the ROBOT while the ROBOT is in the STARTING CONFIGURATION at the beginning of a MATCH. This will greatly facilitate analysis in case of problems.
As Jason has pointed out, your modem is your link during match play. To hide it behind sheet metal will cause loss of data and possible loss of handshake. In spite of the obvious external antenna, there is also an internal antenna. Remember this is a two way device, so there is a transmit and receive antenna. The modem should be mounted in a mostly vertical position to keep the same polarization as the field modems and away from large pieces of metal if at all possible.
I also noticed the 9 volt battery in your pictures...
<R43> The only legal main source of electrical energy on the ROBOT during the competition is the 12VDC non-spillable lead acid battery provided in the 2008 Kit Of Parts.
and
<R45> Items specifically PROHIBITED from use on the ROBOT include:
 Primary 12v batteries different from those provided in the Kit Of Parts (i.e. manufacturer and part number must be the same as those provided in the Kit Of Parts)
 More than one primary battery, or more than one back-up battery
One last thing, I will be looking for sharp edges that may puncture people or playing field objects. So be ready to have all the edges checked over during inspection. I like the nice big window for the main breaker. Field personnel will be very happy if you identify it's location on the top and back of the robot. Don't forget your team numbers and school name and sponsors.
This is a very impressive robot for a rookie team. Congratulations!
Hope this helps.
Unread 09-02-2008, 23:51
FRC #2518
thank you all soooo much.... you guys are awesome
Unread 09-02-2008, 23:56
AKA: Dan
Speaking of 9v battery (as pointed out you can't use it), your IR reciever is going to have difficulties hidden in the box too...
Unread 10-02-2008, 00:00
FRC #2518
the IR board is mounted temporarily, in the finished one it will be mounted underneath the Lexan cover...
speaking of that, will we be able to get a signal through lexan?
Unread 10-02-2008, 00:08
AKA: Dan
That's a good question. My guess is lexan won't block IR, but it should be easy enough for you to test. My instinct tells me it wouldn't be a good idea, because depending on angle your signal my reflect rather than pass through (like visible light).
Unread 10-02-2008, 11:53
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Just a quick look from me and the first thing I noticed is the angle of the front and rear panels. From the floor to 8" up, the robot and frame shall be vertical within 10 degrees. (Not including bumpers.) Are they within 10 degrees?
Team numbers and weight also come into question immediately. Maybe it just looks heavy.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Inspection question Sqwigy Pneumatics 12 08-02-2008 02:00
A Question about MPLAB Barchechath Programming 4 14-09-2007 16:24
Question about servos Xevvie Programming 1 28-11-2006 20:27
Quick question about sensors..plz help thnx pheNIX637 Technical Discussion 6 30-10-2005 02:52
Question about groups Mike Ciance Chit-Chat 1 14-06-2004 12:50
