Go to Post I believe that those who have a clear understanding of their capabilities, both physical and financial, and design and build within those capabilities are the teams that succeed. - Daniel_LaFleur [more]
Unread 09-02-2008, 23:02
Spiders Spiders is offline
Rookie Team
FRC #2599 (Full Throttle)
Spiders is a name known to allSpiders is a name known to allSpiders is a name known to allSpiders is a name known to allSpiders is a name known to allSpiders is a name known to all
Send a message via MSN to Spiders Send a message via Yahoo to Spiders
Question Compressor Startup
How do we get the compressor to start up? its all connected through a spike to the fourth relay output, the spike it getting power but it is not turning on. please help.
Unread 09-02-2008, 23:06
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Compressor Startup
Do you have the pressure switch plugged in to the OI?
Also the bot should be tethered.
Unread 09-02-2008, 23:08
If using MPLAB the default IFI code assumes the pressure sensor is in Digital Input 18 and the compressor spike is on Relay 8.
If you're using something else just let us know what it is.
Unread 09-02-2008, 23:09
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
You need to program it and install the pressure switch for it to work and be legal.
Program using this code and plugging the spike into relay port 8 and the pressure switch into Digital IO 18, or you can change it.
relay8_fwd != rc_dig_in18;
relay8_rev = 0;
Make sure you have the PWM cable fully inserted into the SPIKE as well.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Rookie Team
No, but where gonna do that right now rq, The bot should be tethered? what do you mean?
Unread 11-02-2008, 14:59
itsme itsme is offline
FRC #2217 (FOMH)
itsme is an unknown quantity at this point
First of all you need to program it as said above. Second of all you need to connect the red tether cable from the Robot Controller (RC) (from 'tether' connection) to the Operator Interface (OI) (to the 'tether' connection).
Now, when you switch the power on (the RC is connected to the circuit and gets power), it'll start working. It will reach 115 PSI and the pressure switch will turn its boolean position. This will make the program to stop the compressor until the pressure gets under 95 PSI.
Be sure to connect the pressure switch with a PWM cable to a digital input on the RC.
2007 Israel Regional GM/Technion Rookie Allstars
Participated in 2007 Atlanta World Championships (Newton Division)
Unread 11-02-2008, 15:11
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The tether cable replaces the radio link, for testing purposes. It lets the OI talk directly to the RC. It's a good idea to have the robot sitting on something besides it's wheels when using the tether cable, too.
Unread 11-02-2008, 15:15
The switch should be connected to the black (ground) and white (signal) wires of the cable. Do not connect anything to the red (power) wire, and it would be best to put some electrical tape over the cut end of that wire to prevent it from accidentally contacting anything.
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
breaker tripping on robot startup Bleric Electrical 2 12-02-2005 10:25
Startup/Shutdown sounds Jeff Rodriguez Chit-Chat 4 06-06-2004 22:42
Mplab startup error Team 869 Programming 6 25-01-2004 10:41
Wanted!!! Team startup information archiver 2001 2 24-06-2002 01:15
