Go to Post OMG I'm a nerd! :ahh: - JBotAlan [more]
Unread 09-02-2008, 17:26
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is offline
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
Analog to Digital Conversion too Slow
We are trying to make a set of shaft encoders for our robot, but we are having some major problems. We are using the vex line tracker set's light sensors, and have made a plate with holes in it that gives us suffiecient change in value for each state. We made an interupt to check the sensors, but the conversion from analog to digital is so slow, we can't read fast enought to get accurate values at high speeds. We have heard about using digital sensors, but wanted more input before investing.
Thanks for the help...
Unread 09-02-2008, 20:05
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: Analog to Digital Conversion too Slow
you're using the vex already...why not just buy the vex encoders and modify a drive shaft? i really dont know what to say....nothing personal or anything, i just dont think you'll get it to work properly. if you do, please let me know
Good luck!
Unread 09-02-2008, 23:21
dtengineering's Avatar
dtengineering dtengineering is online now
AKA: Jason Brett
You might want to consider using a compartor like the LM339 in a custom circuit. The comparator will compare the voltage from your sensor to a voltage that you determine (using a voltage divider... just two resistors... you could even make one a pot to make it even easier for setting up) and give you a digital output when you exceed a the set voltage.
We use an OPB706A reflective IR sensor when building mini-sumo robots. It is capable of detecting the white ring around the sumo ring against the back blackground of the ring using only a couple of resistors. One to protect the IR LED from over current, the other a "high" value to tie the output of the phototransistor to ground. We measure the voltage between the high value resistor and the OPB and find that it works well in that application... but only if the sensor is within 2mm of the surface.
Jason
Digital to OI Analog marcan Control System 33 05-02-2007 12:46
Camera servos too slow, help please Lablabla Programming 9 19-01-2007 11:59
Analog to Digital Conversion Help Der Rowan Programming 4 23-01-2006 00:17
Kitbot/cims/transmissions running too slow? Swampdude Technical Discussion 28 23-01-2005 11:17
How slow is too slow? Joe Ross Rules/Strategy 23 12-10-2004 20:23
