Go to Post I think that one of the most fantastic parts about FIRST is that the biggest and most successful teams are also the most abiding to the rules. - Matt Adams [more]
Unread 08-02-2008, 22:12
sonicx059's Avatar
sonicx059 sonicx059 is offline
Philosophy or Robotics? BOTH.
FRC #1439 (ROBO Raiders)
sonicx059 will become famous soon enough
Send a message via Yahoo to sonicx059
Attaching a lcd
Well i thought it would be cool to attach an lcd to the oi that has the dashboard viewer on it. Problem is i am not sure how i should go through with this. Do you have any ideas on how i can do this open for all suggestions or comments.
The right path is my path.
Knowing is not enough, you must apply.
Willing is not enough, you must do. ~Bruce Lee
A man is bound only by the chains that he binds himself with. ~Demario Mitchell
Unread 08-02-2008, 23:59
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: Attaching a lcd
I think the dashboard viewer data link is RS-232 carrying binary data packets. You can't drive a LCD directly, even a LCD that has a RS-232 interface won't work because the messages will not make sense. And the LCD needs power.
You could get a very simple little board (like a rabbit) and program it to receive the binary data and drive an LCD. That would very cool.
HTH
Unread 09-02-2008, 23:24
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: Attaching a lcd
wait till you see team 11's box lol
Unread 10-02-2008, 20:03
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Re: Attaching a lcd
How did they do it? The output is designed to feed a PC that runs a program that FIRST provides. You could replace the PC and the program with a small board with a serial link that can drive the LCD and some custom code. I'm reasonably sure you can't just simply pipe it to a simple LCD module.
HTH
Unread 10-02-2008, 23:37
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Attaching a lcd
If you go on the IFI website and download the zip file for the dashboard viewer they tell you all of the specs on the data that comes from that port. I was thinking of exploring that this year as well
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 11-02-2008, 09:41
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Attaching a lcd
Find a mentor with a pocket pc or palm pilot and con them into allowing you to plug it in
LCD NinJA999 Programming 3 18-01-2008 22:13
Plasma or LCD TV? Wayne Doenges Chit-Chat 10 21-12-2007 14:34
LCD monitors robot180 IT / Communications 30 15-06-2006 21:55
3-D LCD Screen Joe Matt Chit-Chat 5 17-10-2002 23:32
LCD display James Crivellone Rules/Strategy 6 06-01-2002 10:22
