Go to Post (If Dean still says 'Nationals', how can you ridicule a rookie team for it? Come on.) - Amanda Morrison [more]
Unread 09-02-2008, 23:40
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Need an answer super quick, keyang motors!!!
does anyone know how to wire both the left and right hand motors. could you please show a diagram or video
R.C.
MadTown Robotics Team 1323
Unread 09-02-2008, 23:48
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Need an answer super quick, keyang motors!!!
Inside the little black cover are two leads, if you don't have a connector, use two other connectors, slide one onto each lead and power the motor.
Unread 09-02-2008, 23:50
R.C.'s Avatar
can you upload a picture or video of how to put it on or what the connector looks like
R.C.
Unread 10-02-2008, 00:03
I don't remember whether the KOP comes with the right connector, but we've used these crimp connectors to connect the Keyang before:
http://www.cybermarket.co.uk/ishop/i.../t_783_233.jpg
They just slide onto the leads on the motor.
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
I didn't think to take pictures when I was doing it this afternoon, and I can't get back into the shop until after work Monday, but here's a description of how I did it...
Required equipment:
- terminals for Keyang motor (see KOP checklist page 12 for photo)
- terminal housing (also on KOP checklist page 12)
- Wire (#12 AWG)
- Soldering Iron
- solder
- Needle nose pliers
The terminals break off the connecting strip (wiggle it back and forth a couple of times). Take one of the terminals and a piece of wire stripped to an appropriate length. Using pliers, bend the little metal tabs around the wire to hold it in position. Next, solder it in place. Once it cools off, perform the customary jiggle test to ensure the wire is solidly in place. Repeat with a second terminal.
On the back of the terminal is a little hook that will latch into the housing if inserted correctly. Before inserting it into the housing, you may want to test-fit the bare connector onto the motor's electrical connection to make sure it's ok. Once you're sure they're in good condition, insert the terminals into the plastic housing.
The housing will only fit onto electrical connector on the motor one way. The little tab on the side of the housing will lock into the motor's connector to keep things from working loose.
I hope this helps.
Unread 10-02-2008, 00:46
R.C.'s Avatar
could someone tell me how the connector looks in a picture, where to get it, or how to put it on through a picture
R.C.
Unread 10-02-2008, 00:47
R.C.'s Avatar
ok, still need pictures for the electrician person thanks
R.C.
Unread 10-02-2008, 01:50
You've been told where they are. KOP checklist, page 12.
Unread 16-02-2008, 18:40
The_Ravioli_Man's Avatar
The_Ravioli_Man The_Ravioli_Man is offline
is A Dew Drinker for Life! Woot!
AKA: Justin
FRC #2028
The_Ravioli_Man will become famous soon enoughThe_Ravioli_Man will become famous soon enough
Send a message via AIM to The_Ravioli_Man Send a message via MSN to The_Ravioli_Man
Thumbs up Re: Need an answer super quick, keyang motors!!!
a mentor and I just went to some local autopart stores to see if we could find the right hook-up for the -023 motor and we believe we found a match. If you all still need to find this part, go to your local autopart store and tell them part number EC86, it looks very, very, very close to the hook-up required for it.
Just thought I would let everyone else know in good sportsmanship
Representin that 116 Clique & The Salvation Squad til the day I die!
{116 Clique} I am not ashamed of the gospel, because it is the power of God for the salvation of everyone who believes. (Romans 1:16)
But He was pierced for our transgressions,
He was crushed for our iniquities;
the punishment that brought us peace was upon Him,
and by His wounds we are healed.
Isaiah 53:5
Do not let any unwholesome talk come out of your mouths, but only what is helpful for building others up according to their needs, that it may benefit those who listen.
Ephesians 4:29
NOTW = Not of This World
I wanna finish last,
last in the world's eyes.
no matter what I do,
I will be first in Your eyes
Finish Last - Stellar Kart
Keyang Motors R.C. Motors 1 13-02-2008 20:23
Need a quick answer!!!! latonya Motors 1 09-02-2008 18:22
Does your team need keyang motors? tdlrali Motors 0 19-02-2007 01:03
Wiring the Keyang Motors aaeamdar Electrical 3 15-02-2007 07:49
Keyang motors zarb OCCRA 1 22-09-2003 01:44
