Go to Post When someone asks me to define Gracious Professionalism, I'm just going to send them to AndyMark. - rsisk [more]
Unread 10-02-2008, 04:55
hinewwiner hinewwiner is offline
hinewwiner is an unknown quantity at this point
ADXRS150 default voltage is too low..
Hello
Thanks for all your help with my previous post.
Now I am having trouble with the sensor.
In the manual, it says that the default voltage (at null) is 2.5V. but I am getting like 2.13V. It still behaves right. (it goes up or down as I rotate the sensor).
Do you guys think it is bad sensor from factory? I know it wouldn't matter for using the sensor but I am kinda worried if there is a something wrong with sensor.
The input voltage is exactly 5V.
Thank you
Unread 10-02-2008, 05:12
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: ADXRS150 default voltage is too low..
Gyros don't always perfectly center where you might expect... odds are that your gyro is just fine. Common practice is to check the value of the gyro at startup (after everything has settled), and then use that as your neutral value.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Set Default Digital inputs to Low? How? bad Analog value? Generalx5 Programming 11 04-01-2007 18:57
ADXRS150 gyro yaw rate sensor Brian M. Electrical 13 17-10-2004 02:28
ADXRS150/300 Sensor m0rph3us Electrical 2 06-02-2004 22:37
Bug: Login Problems - Session timeout value too low? DanL CD Forum Support 4 09-01-2004 16:33
Voltage Byte -> True Voltage Ulibrium Technical Discussion 11 01-03-2002 08:55
