Go to Post You mean i can do something with the Kinect other than put large dents in wall with a robot? Rad.. - rachelholladay [more]
Unread 08-02-2008, 20:06
Best Available Data
FRC #1778 (Chill Out!)
Making Bumper Weight?
Last year, our robot was completely surrounded by standard bumpers. We built them to specification, with holes drilled in the 3/4" plywood to make weight. As of this Q&A that is no longer legal. Our bumpers are just as specified <R08> and cover the perimeter of the the robot base completely, with the addition of some embroidery fabric. They weigh a little bit more than 16 pounds. Has anyone else run into this problem?
Unread 08-02-2008, 20:14
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: Making Bumper Weight?
You guys gotta be using some dense plywood, we usually build our robots to the maximum dimensions and our bumpers never exceed 10-11 pounds!
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 08-02-2008, 21:39
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
+1 on the dense plywood ours only weight like 10 or 11 lbs
-Dustin Benedict
Unread 08-02-2008, 22:19
Fab.Master's Avatar
Fab.Master Fab.Master is offline
FRC #0617 (Locomotives)
Fab.Master will become famous soon enough
could also be the number or type of fasteners used
Unread 08-02-2008, 23:10
330's bumpers last year made weight, and they would be fully legal this year (other than having been on a previous robot and being fabricated items).
Unread 08-02-2008, 23:13
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Another vote here for 10 or 11 pounds... that's how I remember them weighing in last year, and we had a full set of bumpers for 28x38. Are you sure that's plywood you're using, and not 3/4" aluminum?
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 08-02-2008, 23:21
in between teams
AKA: Luke Van Oort
Or, say, rock maple or walnut plywood (I have never seen either of those in plywood form though... its kind of unfortunate, those would be some darn strong materials). Actually, it wouldn't surprise me if the plywood used was made of birch... while not as heavy as maple, it is a bit heavier than pine, for example (and I think it is used in boats, so it shouldn't be that hard to come by).
Team 1219: 2009 - Mentor
Unread 09-02-2008, 06:50
GaryVoshol's Avatar
Cogito ergo arbitro
What kind of hardware are you using? I ran into weight problems one year when I used 1 x 1/8 angle to protect the edges. Now we are using 3/4 x 1/16 angle on the 5" ends, 1/2" on top and bottom edges.
If that doesn't help, the only thing I can suggest is to make one or more of the bumpers smaller. You'd have to eliminate about 8-10 linear inches, still covers far more than 2/3, and if done judicially would most likely give you the protection you desire. Good luck.
(since 2004)
Unread 09-02-2008, 10:02
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I guess we'll find out today...we are planning on using heavy hardware so it's easy to get the bumpers on and off quickly (bolt and nut, but they are big!), although only two bolts per bumper.
Also we are not planning on using the aluminum angle, because it's so much work to make all those parts and screw them on. Lots of staples will have to do....again...
Thanks for the reminder to check weight before we actually put them together!
Unread 09-02-2008, 13:23
lancerbotics's Avatar
lancerbotics lancerbotics is offline
FRC #2250 (Lancerbotics)
lancerbotics is an unknown quantity at this point
If we have read the rules correctly, as long as you are using the standard bumpers as they are diagrammed in the rules, they do not count against your weight or dimensions. Is this correct or are we totally off base?
Unread 09-02-2008, 13:58
Correct...HOWEVER, they have their own weight restriction (15 lbs) and size (in the Bumper Zone, they can't extend more than a few inches from the robot).
Unread 09-02-2008, 15:17
aapl.jlo's Avatar
aapl.jlo aapl.jlo is offline
Advertising Leader for Team 858
AKA: Puma
FRC #0858 (Delphi Demons)
Team Role: Photography
aapl.jlo is an unknown quantity at this point
I'd side with these guys, those are some heavy bumpers. Still, I would think that the more weight you could get at the bottom the better since we're going to be using robots that reach up high for the overdrive balls. Still I haven't read enough to know how heavy you can make them.
Unread 10-02-2008, 13:05
Best Available Data
We're already using exclusively 1/16" angle. I'm not sure how they're attached, but in the past it's been with some decently sized bolts. We'll probably look into different plywood.
Unread 10-02-2008, 15:31
Mr.G Mr.G is offline
AKA: Kevin
FRC #0326 (Xtreme Eagles / Romulus High School / General Motors)
Mr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond repute
Send a message via AIM to Mr.G
We are also overweight on our bumpers without even using the angle aluminum. I can't believe how much time we have wasted on these things, they came out nice, but are useless right now until we can get some weight out of them. I hope FIRST doesn't keep this mandatory bump rule for next year.
Unread 10-02-2008, 16:05
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
I agree,I know they want to cut back on defense, but mandatory bumpers stunt creativity, and force a rectangular robot. They also make any design involving changing orientations really difficult. Personally I dislike bumpers, but rules are rules, and we'll just have to cope.
bumper coolguybigt Technical Discussion 4 27-02-2007 16:40
bumper weight chippermonky Technical Discussion 10 09-02-2007 14:42
Weight? Estmate weight? Arkorobotics General Forum 21 29-01-2007 17:34
Wait...weight...weight!!!! Greg Perkins General Forum 3 22-02-2006 07:42
Bumper or No? WebWader125 Technical Discussion 19 11-01-2006 01:28
