Re: MPLAB SIM : Stack Overflow Error
I solved stack overflow issue by adding the following code to ifi_frc.h:
#ifdef _SIMULATOR #define RESET_VECTOR 0x000 #define HIGH_INT_VECTOR 0x008 #define LOW_INT_VECTOR 0x018 #else #define RESET_VECTOR 0x800 #define HIGH_INT_VECTOR 0x808 #define LOW_INT_VECTOR 0x818 #endif Also, you need to remove or comment out the following lines in ifi_frc.h: //#define RESET_VECTOR 0x800 //#define HIGH_INT_VECTOR 0x808 //#define LOW_INT_VECTOR 0x818 |
| Using MPLAB SIM | koenig3456 | Programming | 5 | 11-02-2008 14:39 |
| stupid Array error: Error [1300] stack frame too l | Validius | Programming | 7 | 27-01-2006 10:53 |
| MPLAB SIM debugger Questions | Chris_Elston | Programming | 2 | 16-01-2005 11:28 |
| MPlab error | ryan_f | Programming | 9 | 24-05-2004 07:30 |
| using the MPLAB IDE MPLAB SIM simulator | WizardOfAz | Programming | 1 | 03-11-2003 01:24 |
