Go to Post Have you hugged your programmer today? - Gabe [more]
Unread 10-02-2008, 16:40
robofan robofan is offline
FRC #0540
robofan is an unknown quantity at this point
Re: Using MPLAB SIM
I solved stack overflow issue by adding the following code to ifi_frc.h:
#ifdef _SIMULATOR
#define RESET_VECTOR 0x000
#define HIGH_INT_VECTOR 0x008
#define LOW_INT_VECTOR 0x018
#else
#define RESET_VECTOR 0x800
#define HIGH_INT_VECTOR 0x808
#define LOW_INT_VECTOR 0x818
#endif
Also, you need to remove or comment out the following lines in ifi_frc.h:
//#define RESET_VECTOR 0x800
//#define HIGH_INT_VECTOR 0x808
//#define LOW_INT_VECTOR 0x818
MPLAB SIM debugger Questions Chris_Elston Programming 2 16-01-2005 11:28
MPLAB Variable Simulator? Chris_Elston Programming 3 18-02-2004 12:08
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
