Re: 120 psi
Look for the arrow on the regulator. Think of the air as coming "in" the stem of the arrow and low pressure air heading out the "pointy bit" of the arrow. The two side ports are also low-pressure. You will also notice if you look in the ports on the regulator that one looks different inside than the other three. This one is your inlet.
Jason |
| Trackball PSI | pumbaa2007 | General Forum | 2 | 12-01-2008 19:39 |
| Showing PSI in user mode? | Billfred | Programming | 12 | 02-02-2005 16:52 |
| Higher PSI in air Tanks | Projectchon | Pneumatics | 8 | 01-02-2005 15:05 |
| PSI formula for pneumatic pistons | Ryan | Pneumatics | 10 | 13-01-2004 12:56 |
| pic: ~850 PSI Robot | CD47-Bot | Robot Showcase | 28 | 17-05-2003 15:32 |
