Go to Post After each match the pit crew gathers up the parts from the field and finds a new and interesting way to assemble them. - tsaksa [more]
Unread 10-02-2008, 16:57
team2061's Avatar
team2061 team2061 is offline
Gilberto Gonzalez
AKA: team 2061 captain/mechanical
FRC #2061 (PIONEERS)
team2061 will become famous soon enoughteam2061 will become famous soon enough
Re: 120 psi
Originally Posted by dtengineering View Post
Look for the arrow on the regulator. Think of the air as coming "in" the stem of the arrow and low pressure air heading out the "pointy bit" of the arrow. The two side ports are also low-pressure. You will also notice if you look in the ports on the regulator that one looks different inside than the other three. This one is your inlet.
Jason
Take your regulator (set to 60 PSI) and turn the whole thing 180 degrees. (Disconnect the tubing first, then reconnect it after turning.) That should solve it.
What happens should be:
120 --> Reg.--> 60
What is actually happening is:
120-->.geR --> 60, which causes the 120 PSI to bleed off to 60 PSI.
ok that makes perfect sence let me go try it and I'll see what happens, thanks again
2007 Las Vegas Highest Rookie Seed Award
2007 Las Vegas Regional Quater-Finalist
2007 Las Vegas Best Rookie Award provided by team 1547 Where's Waldo
2007 Las Vegas Regional Rank 7 of 51 teams, 2nd Seed
Trackball PSI pumbaa2007 General Forum 2 12-01-2008 19:39
Showing PSI in user mode? Billfred Programming 12 02-02-2005 16:52
Higher PSI in air Tanks Projectchon Pneumatics 8 01-02-2005 15:05
PSI formula for pneumatic pistons Ryan Pneumatics 10 13-01-2004 12:56
pic: ~850 PSI Robot CD47-Bot Robot Showcase 28 17-05-2003 15:32
