Go to Post In an education culture that hinges on having the perfect grades and perfect SAT scores to get into the perfect colleges, I enjoy providing an environment where students are encouraged to test their own hypothesis, challenge their assumptions, and regularly fail. - Michael Corsetto [more]
Unread 10-02-2008, 17:19
holty531 holty531 is offline
FRC #2441
Team Role: Electrical
holty531 is an unknown quantity at this point
actuator does not extend!
if we extend the actuator, then turn on the robot, the actuator retracts.
when we pull the trigger button:
relay6_fwd = p2_sw_trig;
relay 6_rev = 0;
the green light on the spike relay goes on, then the yellow LED on the festo solenoi goes on, but the actuator does not go on!
is this a programming problem or penumatics problem?
Unread 10-02-2008, 17:25
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: actuator does not extend!
What PSI are you running through the Festo?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 10-02-2008, 18:20
FRC #2441
the main pressure regulator is at 60psi
Unread 10-02-2008, 22:10
Clifford Clifford is offline
AKA: Clifford Harrison
FRC #2658
Clifford is an unknown quantity at this point
Is that what's running into the actuator or do you have a secondary regulator (Monnier) between the Festo and the actuator?
Clifford Harrison, Alumni & Mentor
FRC Teams 2658 & 3749
FTC Team 5135
Unread 10-02-2008, 22:12
Imaginary Friend
AKA: Kevin Li
Team Role: Student
The Festo has to run at atleast 30 PSI, I assume that's why Clifford and I were asking.
Kevin Li
596 - Sciclones
Unread 10-02-2008, 22:17
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
Did someone turn the little flow control valves on the actuator (if mounted) all the way off?
Unread 11-02-2008, 00:32
FRC #2441
i decided to just not use the festo and try out the smc single solenoid, and that works like a charm. it extends when we press button and retracts when we let go without us changing the simple program.
is the festo different?
Unread 11-02-2008, 08:40
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Well After you release the power to the SMC it will stay in the last position it was in.
Kevin Li
596 - Sciclones
Unread 11-02-2008, 10:42
Not the SMC single solenoid. All single solenoids behave the same way returning to a home position when there's no power.
The double SMC is what you're thinking of.
The Festo should behave identically. The only things I can think of are if it was tubed incorrectly or if it's just not working.
Unread 11-02-2008, 11:38
Racer26 Racer26 is offline
1075 Has used pneumatics extensively in all our robot designs. Our arm last year was powered by pneumatics.
We've found that the Festo valves seem to be the least robust and most prone to breaking. Never mind that they're useless for more complicated setups than just operating a single ram, since you can't screw fittings into them, and they are a 4 port design, rather than a 5 port one.
Unread 11-02-2008, 14:17
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Yes I meant the SMC double, there isn't a SMC single in this years kit so I assumed they meant the double. Or Is there?
Kevin Li
596 - Sciclones
Unread 11-02-2008, 14:22
Yep, there is a single SMC in the kit as usual and that's what they said they swapped the Festo for.
..there isn't a SMC single in this years kit so I assumed they meant the double. Or Is there?
Unread 11-02-2008, 14:33
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Hmm I see it now.
Kevin Li
596 - Sciclones
To extend or not to extend the ship date! FIXIT General Forum 61 17-02-2007 14:47
Project does not build team 803 Programming 5 27-02-2006 17:03
Ok, this does not make sense.... Michael Hill Math and Science 6 19-10-2005 17:42
Program does not end NNSWIZ Programming 4 21-03-2005 22:33
How does the rotary actuator work? kvzrock Pneumatics 10 26-01-2004 22:32
