Go to Post Grease your gearboxes folks! Gears need grease, otherwise they kerplode. - s_forbes [more]
Unread 10-02-2008, 16:58
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: Team 2415: We Suck...
Thats pretty interesting. I wouldn't have thought to use a hand held vacuum. Ours is slightly bigger and more powerful
http://www.chiefdelphi.com/media/photos/30155
Mentor 2415
Unread 10-02-2008, 17:04
Ian G Ian G is offline
BUILD SUCCEEDED
FRC #2415 (WiredCats)
Ian G is an unknown quantity at this point
Send a message via AIM to Ian G
Awesome! How large is your dome? With our 20" dome, our vacuum system produces about 200 lbs. of attachment force. Which should be plenty.
Unread 10-02-2008, 17:08
AKA: Sean
We're using a 21" funnel. The biggest thing with ours is that we lock onto the ball immediately by just touching it. We dont have to be precise or wait for the vacuum to lock. I think ours was calculated at over 300lbs of force but we are also using 2 fisher price motors and a larger impeller. Either way thats an awesome robot especially for a rookie team.
Mentor 2415
Unread 10-02-2008, 17:27
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Wow we discussed this briefly for our team and didn't think it would work, congratulations.
Doug Leppard
Unread 10-02-2008, 17:34
jimbot's Avatar
jimbot jimbot is offline
FRC #2083
jimbot will become famous soon enoughjimbot will become famous soon enough
So did our team, we even built a vacum, but it had no where near the strenght of that one. we decided on a mortor/catapult desighn.
Unread 10-02-2008, 17:43
AKA: Sean
Honestly I didn't think it would work either but thats why we have an engineering mentor that specializes in pneumatics who had the whole thing figured out and taught all of us how it worked. We're also shooting the ball and our current prototype is getting about 6.5ft completely vertically and 12 ft when launched at a 45 degree angle
Mentor 2415
Unread 10-02-2008, 17:59
Maggie27's Avatar
Maggie27 Maggie27 is offline
Maggie
AKA: Maggie
FRC #1708 (Natural Selection)
Maggie27 has a spectacular aura aboutMaggie27 has a spectacular aura aboutMaggie27 has a spectacular aura about
Send a message via AIM to Maggie27
That's an amazing design.
Most definately. [:
Practice makes "perfect".
(I put perfect in quotations b/c nothing is ever perfect)
Unread 10-02-2008, 18:00
Maggie27's Avatar
Maggie
AKA: Maggie
Impressive.
Unread 10-02-2008, 18:41
GaryVoshol's Avatar
Cogito ergo arbitro
I would have never thought at team could create enough suction to pick up a ball. Great job.
Have you tried it on various inflation levels? While the balls in competition will be replaced if they go seriously flat, they will still use them if they're just a little soft.
I didn't see a good enough side-on view, so I have to ask the inevitable question - does it stay within 80 inches?
(since 2004)
Unread 10-02-2008, 19:06
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
Yes we have tried both FULLY inflated and half way. We will actually try almost no air tomorrow.
Thanks for the compliments!
Unread 10-02-2008, 20:28
Priyadarshy's Avatar
Priyadarshy Priyadarshy is offline
FRC #0612
Team Role: Mascot
Priyadarshy has a spectacular aura aboutPriyadarshy has a spectacular aura about
Send a message via AIM to Priyadarshy
WOW You guys suck so much its impressive.
Good luck at regionals, maybe if you suck enough you will win a whole bunch of awards and matches!
2008 NASA/VCU Team Spirit Award
2007 Chesapeake Finalists
2007 Chesapeake Entrepreneurship Award
2007 NASA/VCU Chairman's Award
2007 NASA/VCU Semi-Finalists
2006 Chesapeake Chairman's Award
2006 Chesapeake Woodie Flower's Award
2006 NASA/VCU Engineering Inspiration Award
Unread 10-02-2008, 21:31
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Nice Bot. It looks like its really hard to grab the ball. how long does it take for u guys to score
R.C.
MadTown Robotics Team 1323
Unread 10-02-2008, 22:28
Jaybee1405
Posts: n/a
awesome! great idea
P.S. Please don't let mentor martha pick the music for your next vid. K thanks
Unread 10-02-2008, 22:30
santosh's Avatar
santosh santosh is offline
AKA: 2415
FRC #2415
santosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond repute
Send a message via AIM to santosh
As of right now it isnt that easy to grab. However we have four sonar sensors that we are rigging up and we will be able to "see" on a dashboard on our laptop in order to help us grab the ball.
We don't really have a full field setup or anything and since we were in a library, we weren't able to really time it. But if we have the ball in the down position it takes about 10 seconds to score.
And the more we practice the easier it gets because that was literally the first time we drove it. But we really need to practice.
Thanks and good luck to all teams.
2004 - 2007 = 1002
2007 - 2011 = Founding Mentor of 2415
6 regional wins, 3 EIs, 3 Chairmans
kiddies kiddies kiddies
Unread 10-02-2008, 22:50
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I really like the design. I love the thread title
-Dustin Benedict
Mars dust storms suck life out of rovers JohnBoucher NASA Discussion 27 04-09-2007 19:58
610 - Official Test #1, We suck balls good Jonathan Norris Robot Showcase 12 13-02-2006 16:22
If set screws suck . . . Madison Technical Discussion 17 22-12-2003 19:19
this year is going to suck techknights General Forum 15 30-01-2002 09:30
We suck! Jordan A. General Forum 11 08-01-2002 22:48
