Go to Post Why climb up to the scaling rungs when you can move the entire field down to your robot's height? - marcusbernstein [more]
Unread 10-02-2008, 14:16
morpheous115 morpheous115 is offline
Team Role: Student
morpheous115 will become famous soon enoughmorpheous115 will become famous soon enough
Common Ground?
I am mounting a couple of sensors and solenoids in a certain area on our robot and was wondering if we were allowed to connect all of our grounds to a few specific wires that led back to the RC?
For example: For a double solenoid I would have two powers and one common ground and for a couple of momentary switches I would have a common ground etc.
I could not find it specifically in the rules whether we were allowed or not so if somebody could help me out I would greatly appreciate it.
-morpheous
Unread 10-02-2008, 16:50
dtengineering's Avatar
AKA: Jason Brett
Re: Common Ground?
I believe that the answer to your question is yes, you can have multiple low load components grounded through a single wire. Although I cannot find anything in the rules that states this is specifically allowed, I cannot find anything that specifically disallows it, either, which means that the general rule is "is it good engineering practice?" FIRST is pretty good about this and so long as you aren't doing something foolish or dangerous (which you aren't, here) you should get through tech just fine.
Specifically, however, for your momentary switches, I assume that you will be hooking them up to the RC's digital inputs. You may as well use servo cable to connect them, and each servo cable comes with a ground line anyways.
As for the solenoid valve, I believe the set-up you describe has been used many times.
Jason
If you want an official answer, however post a question to the Q&A. That and the rule book are the only official, take-it-to-the-bank sources of information.
Unread 10-02-2008, 18:37
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: Common Ground?
last year we had our spikes (i think 3) all with common ground and the inspectors had no problems with it.
Unread 10-02-2008, 18:42
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: Common Ground?
Everything that feeds off of the breaker panel all returns to a common ground anyway... so as long as your wire is guaged high enough to handle the load you are fine.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 10-02-2008, 19:34
Re: Common Ground?
Can you describe this in a little more detail please? Where was the "star" point for the spike's ground? How did you connect them together?
I do not know the wiring rules off the top of my head. However, I would strongly recommend keeping the ground star points in the same topology as IFI originally intended. As an electrical/RF engineer, I spend a lot of time carefully planning my grounding scheme.
I saw one team that used CAT5 cable (normally used for ethernet) quite elegantly for their sensor wiring. It is ok to common the grounds here because they are all going to the same star point - the RC's analog sensor port.
It is also ok (unless the rules say otherwise) to common spikes together, as they are also going to the same star point.
However, I would not be comfortable commoning a ground for a spike and a sensor. The most obvious reason is that this would couple noise into the sensor. The more dangerous reason is that you probably just bypassed some of the RC's protection circuitry.
One easy way to look at it is to consider your ground path to be a tree, with your battery in the trunk. As long as it is still a tree when you are done, you are probably good.
Does it really matter here? Probably not, but it is a bad habit to get into.
Unread 10-02-2008, 19:47
tseres's Avatar
Re: Common Ground?
we had (i think it was 10awg) wire running from ground on the fuse panel, with the crimp-on connectors going to the grounds on the spikes. so out of all but one of the spikes, there were 2 wires crimped together on the one female connector, and they continued in a chain until the last spike.
sorry, but it's hard to describe...
Unread 10-02-2008, 20:52
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: Common Ground?
Why not just follow the wiring diagram so you dont have to explain any weird looking wiring to the inspectors?
-Mike
Unread 11-02-2008, 07:40
Re: Common Ground?
-morpheous
Morpheus,
There is no specific rule related to wire returns for solenoids except if you think about the wiring for a single solenoid. That wiring requires a pair of wires from the Spike to the solenoid. (red & black) In the Spike user's manual there is a method for connecting a dual action solenoid using both Spike outputs with a common return for the dual action solenoid only. Since First rules do not require adding breakers to the common side wiring, common electrical practice would dictate returning each solenoid on a separate wire back to the breaker panel that feeds that Spike. This prevents some teams from overloading a single #18 wire with the returns from several devices fed from several 20 amp breakers.
Remember that the breaker capacity specifications are dictated by the wire size not the load.
Unread 11-02-2008, 11:43
Racer26 Racer26 is offline
Re: Common Ground?
In many cases commoning grounds together is permissible. Sensors and Double Solenoids are the most common places and the least problematic come inspection time. I am however surprised that the inspector allowed your daisy chaining of spikes together, as I recall we've been told in the past that wasn't allowed.
Differences in inspecting, I guess.
Common ground for sensors? Jared Russell Electrical 1 03-02-2006 07:25
Common team supplies halomaster69 Chit-Chat 9 03-03-2005 02:54
Common Ground on Limit Switches Gary Bonner Electrical 4 18-02-2005 13:24
Common For MAXI MikeDubreuil Electrical 1 10-02-2003 02:35
Most common.... Brian Savitt General Forum 1 05-01-2002 18:34
