Go to Post Someone once said, "I know what finished is, and I know what a robot is, but what is this finished robot you speak of?" - EricH [more]
Unread 10-02-2008, 20:51
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Bumper Rules
so I know that in the rules it says the wood backing of the bumpers can not extend past the corners of the robot.
So here is our situation: our manipulator (in the starting configuration) sticks out in front of the front rail of the chassis (it also stays within the size constraints)
Would the wooden backing be allowed to extend to the same distance that the manipulator sticks out? or just to the corner of the chassis?
Here is an image of what i am talking about (i am just holding last years bumper in place to show what i mean)
http://lh5.google.com/visedan/R6-K9G...JPG?imgmax=512
- Bochek
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 10-02-2008, 20:54
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Re: Bumper Rules
I would say that is in violation of the rules. The intent of the rule is that a robot will not be colliding with a hard plywood support when it should be hitting some soft pool noodles.
However keep in mind that I am not the GDC and hence my opinion does not matter much at inspection.
Unread 10-02-2008, 21:21
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Re: Bumper Rules
You do have a vertical piece of pool tube in the corner that sticks out in front of the plywood corner. There has been discussions about "U" shaped robots/bumpers that cover 2/3rd's of the robot with absolutely nothing in front of the leading edge. I am not the GDC, but I would say that you meet the intent of the rule if you cover three sides. The peril, if anything will be the front edge of your manipulator if it comes into contact with another bumper, field element, robot etc. and it is not protected. If you are questioned about plywood sticking out more than an inch from the corner, why not attached a piece of frame material on top of your existing frame behind the bumper to the edge of the plywood?
Unread 10-02-2008, 21:28
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
Re: Bumper Rules
It looks to me like you've answered your own question right there. The frame constitutes the corners of the robot...right?
Unread 10-02-2008, 21:31
jhaugen jhaugen is offline
J. Haugen
FRC #0842 (Carl Hayden Falcons)
jhaugen is an unknown quantity at this point
Re: Bumper Rules
The rules specifically state that the wood cannot extend past the corner. The picture shows a direct violation.
Unread 10-02-2008, 21:40
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Re: Bumper Rules
- Bochek
I would send you back to the pits...........did you ask the FIRST Q & A?
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 10-02-2008, 21:41
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Bumper Rules
If you left your manipulator down in that position all match long, you might have a valid argument for extending the bumper as shown. But I presume you intend to move the manipulator at some time. Then the leading edge of the frame defines your bumper zone. Once you move the defining edge of your robot, the bumpers have to be in compliance with that new edge. There was already a Q&A for the opposite situation - someone wanted to know how to measure 2/3's if the frame size expanded after start, and the answer was that 2/3's applied during the entire match. I would imagine the GDC would make a parallel ruling for your robot, that the bumper could not extend past the corner of the frame once you moved your mechanism.
(since 2004)
Unread 10-02-2008, 23:48
dtengineering's Avatar
AKA: Jason Brett
Re: Bumper Rules
Well, you could always just bolt on an extension to the side rail of your robot, so that the side rail reached as far forward as the bottom of the gripper. (that's within the starting configuration, right?)
If you are worried about the plywood extending into the corners... just re-define the location of the corners of your robot!
Jason
Bumper Qs Woody1458 General Forum 13 29-01-2009 16:41
bumper coolguybigt Technical Discussion 4 27-02-2007 16:40
Bumper rules robotraj111 Kit & Additional Hardware 1 19-02-2006 20:36
Bumper or No? WebWader125 Technical Discussion 19 11-01-2006 01:28
Regional-specific rules, etc., and do the referees read the rules? Kit Gerhart Rules/Strategy 53 18-04-2005 08:51
