Go to Post It's always FIRST season. - Foss@Team176 [more]
Unread 10-02-2008, 22:22
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Thumbs up Re: Team 1565 Unique Drive System
That's the most amazing thing I've seen all week. It's a thing of beauty.
Unread 10-02-2008, 22:27
Deep Dark's Avatar
Deep Dark Deep Dark is offline
AKA: Dave Woods
FRC #2506 (Saber Robotics)
Deep Dark is on a distinguished road
Send a message via AIM to Deep Dark
As i'm watching the video, i'm thinking:
wouldnt it be cool if the wheels all rotated half way (45 degrees), then all the wheels are 90 degrees to each other and it becomes holonomic drive....
but....yeah. totally unnecessary. Definately a sweet looking system. Congrats! i'm impressed!
Dave Woods
Mechanical Engineer - Rexnord Conveying Equipment (New Product Development)
Alumni - Milwaukee School of Engineering (W-11
May '07 - present: Mentor/Co-Lead - F.R.C. Team 2506 Saber Robotics
May '06 - May '07: Mentor - F.R.C. Team 537 Charger Robotics
May '02 - May '06: Student - F.R.C. Team 537 Charger Robotics
Unread 10-02-2008, 23:07
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
funny story about that.. They did. We had a three stage so we can drive in omni for standard avoiding robots, but programming it turned out harder than we thought, and because nothing else on our bot needs air, we decided to just go for the two stages
Unread 11-02-2008, 11:38
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
Wow impressive, definitely gets my vote for creativity.
Couple of questions:
What made you choose this design over a crab style with 1 motor controlling wheel orientation?
Are you worried about getting pushed (on purpose, or inadvertently) having all omniwheels?
Penn Class 08
Unread 11-02-2008, 13:25
FRC #1360
Could the 1.5" bore piston be replaced with 2 separate 3/4" bore pistons that are identically mounted but move in opposite directions to achieve the same effect?
You can use 1 3/4" bore if you wanted, but we only had a 1.5" at the time, and decided why bother replacing it if we already have a mount made for it.
Can the omnis be replace with traction wheels for more traction or is there too much skid when the wheels orthogonally rotate 90 degrees while the robot is at speed?
No the omnis cannot be replaced, nor have we tried, because of the skidding it does, when switching the wheels at speed. It would seem to me (which is why we didn't try) that the linkage would probably destroy itself if traction wheels were on it.
We wanted to do something unique, and we have no experience with crab or omni for that matter. We decided to make an in-between bot that was easier to build than crab, yet stronger than omni
No we aren't, if someone pushes us, the only way we would move easily is if pushed perpendicular to the wheels (so along the rollers) in which case, we can switch the wheels. Omni wheels are good for traction when being pushed striaght with the wheels. Overall we should have as much pushing power as any four wheel drive bot, from every direction.
Thanks for the comments everyone!!
Unread 11-02-2008, 13:29
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
This is an amazing robot, great job!
I wouldn't go quite that far....keep in mind that when you push up against another robot, much of the weight is transferred to the rear wheels, and you only have two drive motors back there. A normal skid steer 4 wheel drive bot has power to both front and rear wheels on each side from a common transmission, so it has twice the torque available at the rear wheels as yours does.
But this years game seems to be more conducive to quick, highly maneuverable robots like yours, so that should not concern you.
Unread 11-02-2008, 17:51
FRC #1360
well for generalization sake, we are a four wheel drive bot, with omni bot agility (again roughly)
thanks again for the comments!
Unread 11-02-2008, 19:50
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
that is really cool, it looks like a solid drive train
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 11-02-2008, 23:57
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Good Job - I was thinking of building something similar out of Vex equipment. Now I think I'll have to.
Because I'm lazy , will you be able to send me (after the build season perhaps) your algorithms for converting operator inputs into wheel turns and motor spin directions?
What are your operator/driver's controls? Joysticks? Knobs and sliders? Something else?
Does the machine rely on a gyro or a similar device to know which way is pointing (and then combine that info with the operator's inputs when deciding how to point and spin the wheels)?
Blake
Unread 12-02-2008, 20:31
FRC #1360
Blake
Well to tell the truth, the system is really easy, its driven with an xbox 360 controller, like any normal 4 wheel drive, and the "A" and "B" button switch modes, once the modes are switched the program knows what setup it is in (based on what button is pushed) and switchs drive codes accordingly, no gyro, nothing special on it at all. Just designed very well (not to toot my own horn )
Unread 16-02-2008, 19:10
Team56 Team56 is offline
FRC #0056
Team56 is infamous around these partsTeam56 is infamous around these parts
That looks very cool.. I love the way where you guys don't have to turn, just switch the wheels =)
www.team56.com
pic: Team 2404 (TNT) Omni Drive System LaurenH Extra Discussion 12 11-02-2008 17:22
pic: Unique drive concept Joe G. Extra Discussion 36 12-05-2007 20:27
What drive system is your team using? dpick1055 Technical Discussion 22 27-01-2007 23:29
pic: Team 612 Drive System RoboMadi Robot Showcase 7 08-02-2006 16:38
Video: Team 95's Holonomic Drive System kaszeta Robot Showcase 0 08-02-2006 09:54
